I run these in my shit box, seen plenty of track days, skidpans, 8k RPM launches, etc. with the first 2x motors.
https://www.vibra-technics.com/nissan/skyline_r32_r33_r34_gt_gtr_gts_t/623/NIS240M_kit/engine_mount_r33_gts_t_rb25det_r34_gtt
And you guys know, I thrash my car when I can at the track.
Still using the same mounts, some slight vibration but nothing like a car with solid urethane ones. I get a bit of a rock with the idle braps too, extra hard c()nt at the lights.
Might be worth putting in better engine mounts(?), sounds like the stock OEM Nismo branded ones might tear with all the powahs.
 They are labeled wrong, a gtst mount and a gtr mount are completely different
Started installing the inlet manifold
put the first part on along with the drive by wire motor
then the throttles and adjusted rod for the throttles
then the new nismo plenum went on, I didn’t take the lugs off because I like the original finish
  • Like 8
22 hours ago, r32-25t said:
also fitted an oil pressure regulator against the block under the manifold
If it's an opr40, oil feed in and turbo out lines are backwards - it matters on these, it's not a fuel reg where the top 2 side ports are common inlets.
1741931481_Screenshot_20221009-122437_AdobeAcrobat.thumb.jpg.00ddaba2f8f4f6e0d370c4dfef5a1716.jpg
  • Like 3
Ok thanks glad someone picked that up, I didn’t read in the instructions and just assumed it didn’t matter. Will fix it up before I put the engine in
  • Like 3
No worries, you can just rotate it 180 but your gauge port will be unusable obviously pointing towards the block.
All good I’m not putting a gauge in it so won’t be an issue
made all the sensors fit so that the ecu knows what going on and will also allow the factory dash to be retained
built all the scavenge lines, it has 2 from the sump and one straight out the back of the head. Also has a water line from the back of the head to the water neck that the top radiator hose attaches to
engine ready to be dropped into the car
  • Like 2
By having a scavenge line from the head to the pump, doesn’t that take away from what yours trying to do? You have two points in the sump which would be “pulling down” then one at the top of the engine sucking. Kinda like a push and pull situation going on instead of all pull.
  • Like 1
On 23/10/2022 at 7:01 PM, r32-25t said:
All of them are pulling which creates a vacuum in the crankcase, unless Porsche have been getting it wrong since the 60s
Nah man, Porsche have been doing it wrong for decades 😂😂😂
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
