3 hours ago, r32-25t said:
Ok so the reason I decided to cancel all Japan day is I was finishing off the last of the wiring and started to look at having to do the relays and fuses for the fuel pumps, thermo fans, trigger for the power steering pump and etc. after looking at the number of wires that were going into the car, I took a step back and thought nah f**k this there’s a better and much neater way to do this!!
insert pd16 (pdm) here and the problem is solved only issue is I now need to strip the wiring harness, remove the i/o 12 box from it and fit the pd16 instead
I got very lucky and it just happened they came into stock the day after I ordered it, now while this is a set back and will mean having to redo some work, it’ll end up being better for it
Surprised you didn't go the whole hog on the high-end nexus that's ECU and PDM in one! 😛
jealous of that PDM, I'm a poor man playing in a well funded man's sport... I'm stuck with relays and fuses ha ha ha!
I looked at it and worked out I’d either need to buy a nexus plus a pdm due to the the fact the nexus uses 3 of the 25amp out puts or just the pdm if I kept the elite in there
  • Like 1
No matter how many IO you have, you never have enough... Ha ha ha
The only other things I’d want would be more DPI/SPI to measure the 4 wheel speeds and do traction control. not sure my car will make enough power for it to be a real issue though
You're better off doing a GPS speed sensor vs. the wheel speed as your car would bake all 4x wheels, if the surface isn't optimum.
Having front and rear speed sensors and doing a traction strategy on that only works on FWD or RWD cars.
From someone in the GPS industry, you'd want it to be a good GPS module, with an actual accurate output (basically doing a lot of sensor fusion with gyros, compass, and accelerometers) or the TCS won't be that great.
For Brett's car the traction strategy would be for straight line attacks, so the Haltech GPS sensor would be sufficient for traction control in his application.
Fair enough, I can't see it being any where near good enough to compare GPS to wheel speed in most use. Imagine you drove under a tree in a corner, I'm sure we've all had that experience where we were apparently doing 60, then 120, then 30 in the space of a second.
I think with most all wheels drive cars you use both the wheels speeds and the gps, I agree the gps will end up useless in some situations and would be interesting to see how the system would react at those times
Most GPS modules are getting better than that, but still not great unless you're spending big big big dollars.
Biggest problem, is it relies on measuring distance, with decente enough error to make it quite difficult to detect did I really move, or just GPS error?
Which means you can have the GPS thinking you've moved when you haven't, and at the same time you've gone to launch and broken into mass wheel spin.
This is where you need a heap of sensor fusion from everything else.
GNSS and Vehicle Telematics is my niche professional area of work.
You would likely have more reliable wheel spin detection on an AWD using steering angle, TPS, and comparing the individual wheel speeds, as well as rate of acceleration, and comparing that with acceptable rate of acceleration at given speeds for given gears, and more so anticipating if it is wheelspin or not, vs using a GNSS sensor compared with wheelspeeds.
21 hours ago, TurboTapin said:
I was under the impression that Haltech does not allow the use of their GPS speed for traction control. It must be wheel speed sensors.
It definitely can, it just comes up as a speed sensor.
I just gave it a try and it's a no go without an addition wheel sensor. The error states "Traction Control for rear wheel drive requires at least one rear wheel sensor (Or drivetrain sensor) and at least one front wheel speed sensor."
You are correct!
I just played around with it myself and it shows the same error. A workaround is to just create your own Generic and apply ignition correct (as in take timing out) when there's a GPS Speed / Drive Train speed difference.
I'll end up trying this out one day as I want traction control.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
