It will work, but will be way to restrictive and most likely choke the engine around 4k rpm so if you don't plan on reving it over 4k rpm then you will be okay providing you don't over boost a brake the ceramic wheel on the turbo.
I suggest using something alittle bigger, no point building a 25/30 the putting a useless turbo on it. The xr6 ball bearing turbo gt3540 is good value for money can pick them up for around 500$ second hand and are a perfect size for rb30.
Yep I would jam a stocker R34 turbo on it at the moment and then send it to Hypergear to get highflowed when it inevitably dies. Saves a bit of coin now and you should get at least a few months out of it.
