Rb30/25 Build Turbo Question
Hi guys.
I'm currently building an rb30/25det and was wondering if a stock rb20 turbo would be usable to start with?
I will be getting a bigger turbo down the track but was just wondering if it would work.
Thanks
It will work, but will be way to restrictive and most likely choke the engine around 4k rpm so if you don't plan on reving it over 4k rpm then you will be okay providing you don't over boost a brake the ceramic wheel on the turbo.
I suggest using something alittle bigger, no point building a 25/30 the putting a useless turbo on it. The xr6 ball bearing turbo gt3540 is good value for money can pick them up for around 500$ second hand and are a perfect size for rb30.
 Share
