Pressure tested it today and found a hairline crack about 1/4 inch long on 1 intercooler pipe. Can't put a silicone joiner over it in the interim because whoever made the pipe, squashed that particular piece to an oval shape so it won't seal. Found 2 others leaks, 1 was the idle adjustment screw and the other was the bov but that's out of a factory hole cast into the vavle.
Replaced cracked intercooler pipe, problem is miles better but still exists. Only on boost and only in low boost range. Once it gets 4-5psi in its guts it clears up and revs like normal. Get an occasional backfire as it's trying to build boost.
Car was tuned in Feb and hasn't faulted since, pretty certain leak was a new problem. It reared it's ugly head after having a boost spike of 6-8psi briefly while setting up a boost controller. I'll try some known good condition coil packs.
Edited by fmlycar
As in, car was tuned, then you put in a boost controller, and it overbooosted then misfire started.
That's kinda bad.
Yeah it over shot and I backed off as soon as I seen it going past where it should be.
Just pressure tested again and found a line teed off from the boost guage line was leaking slightly. Have fixed that. Went for a drive and hasn't made much difference. Only other leak is out a small hole cast into the bov but that can probably be ruled out if it's always been there.
Car was tuned to 18psi. Ebc is in preparation for another turbo upgrade so I can run a couple boost settings. Everything suggests healthy motor, and tune was very safe as that's what I wanted. Knock never goes any higher than 30 at any given time but is for the most part under 20. Tool it for a high speed run last month and never went above 18 in all gears right up to 6500rpm in 5th
Edited by fmlycar
Took cas off, removed cover surrounding plug and sprayed inside as best I could with circuit board and contact cleaner. Reinstalled and set timing. Has now moved the misfire to more than 1 bar of boost and cleared up down low. does this sound like I should replace it?
Did you rest your timing and a small thing but 15 degrees at 650rpm for a gts25t??? That is not the orange line - each line is 10 degrees.
Mind you, I don't think thats the problem but just to be sure.
Isn't it 20 degrees btdc for series 2? I did 15 to begin with and ran like a complete bag of poo, then set it for 20 and was loads better, but not perfect. I'll check tps values again just to be sure and try borrow a working cas to see if that's it
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
