Should have mentioned it's a auto converted to manual so I think timing is supposed to be 20 deg btdc. That's what it was set at and tuned at anyway.
Is there any way to check the resistance for the CAS to check if it's faulty?
TPS values are 0.42v idle with engine off and 4.06v wot engine off.
Checked TPS again and adjusted to 0.5v closed but only got 3.30v at WOT with a multimeter. This was tested with engine off and ignition on. While running I had very similar result. It's conflicting values with what the power FC was reading this morning. I had 0.49v at idle (car running) and 4.11v WOT. What are the acceptable values for the TPS? This could be my problem if it uses tps feedback for fuelling maps and it's reading low.
Tried a different set of coil packs (splitfires) and didn't improve. So I put my splitfires back in with a plug gap of 0.55 and still no improvement. Don't know if there is another car in town I can lend coil packs off. Only a couple imports here and even less are modified.
Boost won't go over 0.95 bar atm. As soon as it tries to build boost it coughs and hesitates, pops and backfires then will clear up and pull but is now breaking down above 12psi once it finally gets there.
My coil packs look to be in newish condition. Don't want to go throwing 600 at new coil packs if I don't have to or if it's not the problem.
Edited by fmlycar
Checked all earth's. Cleaned aacv while I was at it.
Is there any way to check coil packs with a multi meter? I tried checking between + and - on the coil pack but couldn't get a resistance reading at all. Also tried from the spring in the bottom to every pin and nothing came up on my multi meter. Have I missed something there?
Sounds like a leak under vacuum.
Injector caps, injector manifold seals, Tb shaft seal.
Stuck, busted nrv on the brake booster or pcv valve.
Been loosing any coolant?
Is the keyway flogged out in the CAS/ camshaft drive?
Does the Toyota dealership still have a Dyno?
Pfc's are prone to dry sockets on the boards, can throw up similar issues.... usually more consistent.
Edited by XRATED
No Coolant loss, keyway on cas/camshaft is perfect, no leaks from injector caps or manifold seals. Haven't check TB shaft seal but have sprayed that area fairly liberally with carby cleaner with no change in idle. Not sure if Toyota still have a dyno.
Coated the coil packs in urethane seal coat and regapped the plugs at 0.7 and I did notice a slight improvement initially but still breaking down under heavy load/boost. I think the coil packs are the culprit in this case. I was in denial as they're splitfires and looked to be in good condition, however that couldn't mean there isn't anything wrong with them. Especially since the ignitor is built into each coil pack. Guess all I can do is order some new one's and see how I go. Bit of a roll of the dice but don't have many other options.
If the coils aren't getting enough voltage they will give a low output spark. Tried a temporary decent power feed?
You could buy a set of coils then realize it's the PFC that needs changing, it's more likely if it's older than the coils.
If you've tried other sets of coils with no result then, a new set is unlikely to fix your issue. As Scotty has said, power supply and ground for the coils make an amazing difference.
Your comments about issue improving post coating the coil pack boots.......... I'd try a new coil pack loom, clean your grounding points and/or add an additional ground cable from the back of the head to the battery and add a larger (fused) power wire directly from the battery to the new loom. Clean or swap the ignitor module.
It is odd, spark will usually blow out under peak load and get worse with more throttle and boost.
Leaking fuel injector or poor throttle/accel pump tune or damaged fpr ? Could be flooding to the point of misfire during vac and transition to boost.
I lived and worked in Alice many years ago (had an hr31), so I can empathise. Back then, the local Toyota dealership had a dyno and would tune (mostly Finke buggy's etc) performance cars/buggy's etc.
Power fc is a gtt model and about the same age as the coil packs if not newer (I can dig out the receipt to check). I've checked voltage at the coil packs at idle and they're all getting 14.19v after taking it for a drive last night it is missing at idle and generally running rough.
Will get some new coils packs, plugs and fuel filter and hope like hell that fixes my issue. I could always try my coils in another car and see if it makes theirs run like ass too.
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
