Should have mentioned it's a auto converted to manual so I think timing is supposed to be 20 deg btdc. That's what it was set at and tuned at anyway.
Is there any way to check the resistance for the CAS to check if it's faulty?
TPS values are 0.42v idle with engine off and 4.06v wot engine off.
Checked TPS again and adjusted to 0.5v closed but only got 3.30v at WOT with a multimeter. This was tested with engine off and ignition on. While running I had very similar result. It's conflicting values with what the power FC was reading this morning. I had 0.49v at idle (car running) and 4.11v WOT. What are the acceptable values for the TPS? This could be my problem if it uses tps feedback for fuelling maps and it's reading low.
Tried a different set of coil packs (splitfires) and didn't improve. So I put my splitfires back in with a plug gap of 0.55 and still no improvement. Don't know if there is another car in town I can lend coil packs off. Only a couple imports here and even less are modified.
Boost won't go over 0.95 bar atm. As soon as it tries to build boost it coughs and hesitates, pops and backfires then will clear up and pull but is now breaking down above 12psi once it finally gets there.
My coil packs look to be in newish condition. Don't want to go throwing 600 at new coil packs if I don't have to or if it's not the problem.
Edited by fmlycar
Checked all earth's. Cleaned aacv while I was at it.
Is there any way to check coil packs with a multi meter? I tried checking between + and - on the coil pack but couldn't get a resistance reading at all. Also tried from the spring in the bottom to every pin and nothing came up on my multi meter. Have I missed something there?
Sounds like a leak under vacuum.
Injector caps, injector manifold seals, Tb shaft seal.
Stuck, busted nrv on the brake booster or pcv valve.
Been loosing any coolant?
Is the keyway flogged out in the CAS/ camshaft drive?
Does the Toyota dealership still have a Dyno?
Pfc's are prone to dry sockets on the boards, can throw up similar issues.... usually more consistent.
Edited by XRATED
No Coolant loss, keyway on cas/camshaft is perfect, no leaks from injector caps or manifold seals. Haven't check TB shaft seal but have sprayed that area fairly liberally with carby cleaner with no change in idle. Not sure if Toyota still have a dyno.
Coated the coil packs in urethane seal coat and regapped the plugs at 0.7 and I did notice a slight improvement initially but still breaking down under heavy load/boost. I think the coil packs are the culprit in this case. I was in denial as they're splitfires and looked to be in good condition, however that couldn't mean there isn't anything wrong with them. Especially since the ignitor is built into each coil pack. Guess all I can do is order some new one's and see how I go. Bit of a roll of the dice but don't have many other options.
If the coils aren't getting enough voltage they will give a low output spark. Tried a temporary decent power feed?
You could buy a set of coils then realize it's the PFC that needs changing, it's more likely if it's older than the coils.
If you've tried other sets of coils with no result then, a new set is unlikely to fix your issue. As Scotty has said, power supply and ground for the coils make an amazing difference.
Your comments about issue improving post coating the coil pack boots.......... I'd try a new coil pack loom, clean your grounding points and/or add an additional ground cable from the back of the head to the battery and add a larger (fused) power wire directly from the battery to the new loom. Clean or swap the ignitor module.
It is odd, spark will usually blow out under peak load and get worse with more throttle and boost.
Leaking fuel injector or poor throttle/accel pump tune or damaged fpr ? Could be flooding to the point of misfire during vac and transition to boost.
I lived and worked in Alice many years ago (had an hr31), so I can empathise. Back then, the local Toyota dealership had a dyno and would tune (mostly Finke buggy's etc) performance cars/buggy's etc.
Power fc is a gtt model and about the same age as the coil packs if not newer (I can dig out the receipt to check). I've checked voltage at the coil packs at idle and they're all getting 14.19v after taking it for a drive last night it is missing at idle and generally running rough.
Will get some new coils packs, plugs and fuel filter and hope like hell that fixes my issue. I could always try my coils in another car and see if it makes theirs run like ass too.
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
