You are flirting with danger modifying the Injector settings without a wideband.
The fact the coolant temp appeared to drop would mean the ecu would add fuel, probably the problem all along.
No way did the settings in the ecu change by themselves.
Thats the thing, when I drove it last night nothing had been changed by me. How can the tune go from being fine for months and then all of a sudden be really rich?
Spoke to a workshop in adelaide and he suggested that is has a currupt file. It's getting tuned in 3 weeks so that should clear that up.
Edited by fmlycar
or your water temp sensor is cactus... potentially accessing enrichment values from the water temp correction table...
buy a wide band already, it's cheaper than a new motor.
  • 1 month later...
Im also on the missfire spluttering chain atmo
Brand new spitfires
Brand new coil loom
Brand new z32
Now its time to look on fuel side of things
Pumps are only 4 years old used like 25 times
Could be fpr
Need to get a fuel pressure Guage
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
