You are flirting with danger modifying the Injector settings without a wideband.
The fact the coolant temp appeared to drop would mean the ecu would add fuel, probably the problem all along.
No way did the settings in the ecu change by themselves.
Thats the thing, when I drove it last night nothing had been changed by me. How can the tune go from being fine for months and then all of a sudden be really rich?
Spoke to a workshop in adelaide and he suggested that is has a currupt file. It's getting tuned in 3 weeks so that should clear that up.
Edited by fmlycar
or your water temp sensor is cactus... potentially accessing enrichment values from the water temp correction table...
buy a wide band already, it's cheaper than a new motor.
  • 1 month later...
Im also on the missfire spluttering chain atmo
Brand new spitfires
Brand new coil loom
Brand new z32
Now its time to look on fuel side of things
Pumps are only 4 years old used like 25 times
Could be fpr
Need to get a fuel pressure Guage
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
