Pressure tested it today and found a hairline crack about 1/4 inch long on 1 intercooler pipe. Can't put a silicone joiner over it in the interim because whoever made the pipe, squashed that particular piece to an oval shape so it won't seal. Found 2 others leaks, 1 was the idle adjustment screw and the other was the bov but that's out of a factory hole cast into the vavle.
Replaced cracked intercooler pipe, problem is miles better but still exists. Only on boost and only in low boost range. Once it gets 4-5psi in its guts it clears up and revs like normal. Get an occasional backfire as it's trying to build boost.
Car was tuned in Feb and hasn't faulted since, pretty certain leak was a new problem. It reared it's ugly head after having a boost spike of 6-8psi briefly while setting up a boost controller. I'll try some known good condition coil packs.
Edited by fmlycar
As in, car was tuned, then you put in a boost controller, and it overbooosted then misfire started.
That's kinda bad.
Yeah it over shot and I backed off as soon as I seen it going past where it should be.
Just pressure tested again and found a line teed off from the boost guage line was leaking slightly. Have fixed that. Went for a drive and hasn't made much difference. Only other leak is out a small hole cast into the bov but that can probably be ruled out if it's always been there.
Car was tuned to 18psi. Ebc is in preparation for another turbo upgrade so I can run a couple boost settings. Everything suggests healthy motor, and tune was very safe as that's what I wanted. Knock never goes any higher than 30 at any given time but is for the most part under 20. Tool it for a high speed run last month and never went above 18 in all gears right up to 6500rpm in 5th
Edited by fmlycar
Took cas off, removed cover surrounding plug and sprayed inside as best I could with circuit board and contact cleaner. Reinstalled and set timing. Has now moved the misfire to more than 1 bar of boost and cleared up down low. does this sound like I should replace it?
Did you rest your timing and a small thing but 15 degrees at 650rpm for a gts25t??? That is not the orange line - each line is 10 degrees.
Mind you, I don't think thats the problem but just to be sure.
Isn't it 20 degrees btdc for series 2? I did 15 to begin with and ran like a complete bag of poo, then set it for 20 and was loads better, but not perfect. I'll check tps values again just to be sure and try borrow a working cas to see if that's it
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
