Your plugs will more than likely to be covered in junk by now.... this will cause the increase severity of the misfire problem.
You can learn a lot from pulling the plugs and 'reading' them (although it may be to late now). I'd suggest you pull them asap and post up photo's (keep them in order).
Replace the plugs and at least you will be able to drive it again for a few km's.
Honestly I can't see your O2 sensor being the problem (just unplug it if you aren't sure), fuel filter is a good service item, but unlikely to stop you from miss firing. A wide band is only going to help if the mixtures are actually getting burnt.... as soon as it misses, you will just get rich afr's off the scale-
I'd be buying/borrowing a new coil pack loom and a known good ignition module before buying another set of coil packs.
If you still have issues, pull the injectors and get them cleaned/flow tested.
after that... take it to a mechanic.
I had similar issues with my R33 s2.
I had checked and resoldered the pins in the afm for the plug, made no difference, but it was actually dry joints on the afm board itself. Fixed those up and she's been apples.
Also, is the z32 afm genuine? There are copies floating around
Xrated, it's a s2 motor so the ignitor is built into the coil pack. Unplugging the o2 sensor doesn't make any difference atm so I'm replacing it anyway.
Cef33y, I'll see if anyone in town has a z32 afm I can borrow. I double checked and mine is genuine.
I had the same thing happen to my Stag. I was sitting at the lights one day and it started running real rough. By the time I got home the car was real rough. I turned it off and it wouldn't start again. Checked this, that and the other, no good. Pulled the plugs and they looked OK, although a touch dirty. Changed them and bammo, car fine again.
Jam a multimeter in your car and see if your voltage drops as there's load on your motor or if you can just log it from your ecu.
I had a shit house misfire problem too, turns out was my stock alternator playing up. On idle, it would show up 13.8V but as soon as you increase the RPM it would drop to around 12.2V. Replaced it with a brand new Circuit Sports one and misfire gone!
New coil packs, new 02 sensor, new tps, new plugs. Starts, Idles and drives fine and smooth. As soon as you try and boost it, feels doughy as and misses and doesn't make any power. Still yet to fit a new fuel filter.
Still have to find another afm to try yet
Any workshops in Alice Springs NT you could recommend?
Its something that isn't affecting just 1 cylinder as the last lot of plugs were all sooted up. I just feel like I've gone over everything twice without any luck.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
