Sydney Hr31 Meet - Sunday 19 September 2004 (open To Everyone Though)
There appears to be quite a few HR31's around the suburbs of Sydney. It would be good to have them all together at a meet, so I was thinking we could do this sometime in September. This gives us plenty of time to get those 2 doors looking schmick (plus I don't get back from overseas until August 28th!).
I know of at least 10 club members with HR31s, so we could definitely have a decent sized meet. If only it could end up looking like this ---> Image755.jpg
Here's what I propose:
WHEN: Sunday 19 September 2004
MEET WHERE: Meet 7:45am at Caltex Moorebank (Corner of Nuwarra and Newbridge Roads, Moorebank) ***Departing Caltex at 8am***
WHERE TO: - Head to Avon Dam (some fun roads to get there) for a look and to grab a drink
- Then we head through Mittagong to Robertson (hmmm some nice roads :cheers:)
- Arrive at the Kiama blowhole (plenty of parking). here we can grab some fish and chips for lunch
- After lunch we head back to Robertson, do the bypass, head to Wollongong, and finish up with the Nasho run on the way home
WHAT TO BRING: Full tank of petrol. UHF radio if you have one
Yes we're going to cover a bit of road, but it will be a bloody good day. No doubt we'll find some good photo opportunities as well. I'll have maps printed out for people at Caltex just in case they happen to get lost or wanna detour at some point of the day. (I'll get them uploaded to here as well in good time).
I am keen to get a good showing of HR31 2-doors there, but as usual other cars are welcome. (No dickheads please)
So far we have:
88silhouette (HR31 GTS-X)
fatz (HR31 GTS-X)
RedX (HR31 GTS-X)
31 GUN (HR31 GTS)
boostn247 (HR31 GT PASSAGE)
2 x mates of boostn247 (OZ R31s)
1 x mate of boostn247 (HR31 GT PASSAGE)
Ampho's Waggin (R31 GX WAGON - RB30ET)
Nathan (HR31 GTS-R)
Dave R31 GTS-X (HR31 GTS-X)
TWIST
ED.GTS189 (R31 SILHOUETTE)
88silhouette's brother (R31 SILHOUETTE) - yes, I talked him into bringing the shitbox along for a fang.
Fast31 (HR31 GTS-X)
Bluprint (R31 SILHOUETTE)
1? x mate of Bluprint (OZ R31)
TURBO PINTARA (R31 PINTARA - CA18DET)
BJ (R31 Silhouette)
Clemsa (R31 Ram Raider)
AthlonXP (R31 GXE)
1 x mate of AthlonXP (R31 Pintara)
Dj labby (R31 GXE - RB30ET)
1 x mate of Dj labby (R31 SILHOUETTE - RB30ET)
Andrew from Orange (HR31 GTS-X)
We've got plenty of time before this happens, so offer up any suggestions or criticisms you'd like to make. My email is [email protected] (or [email protected] while i'm overseas from 17/7-28/8). My mobile number is 0402 287 773.
Hope to see you all there.
Cheers, MARK
Guest two.06l
mate did you speak to him yesterday?
and yeah do you wanna call him?
i'm excited boys!
does anyone know of the whereabouts of my old skyline.It is a 1989 HR31 GTS-X it is white in colour and had an eccs rb20det fitted from factory(rare),had r32 automatic transmission, highflow T3/4 hybrid, rewritten ecu,3"mandrel bent exhaust and bleed type manual boost controller.The number plates fitted when sold were GTS-20T and was sold on consignment by Brad Host from the Toyshop in Cardiff.Any info would be much appreciated.Thank You
gday. i only know three hr owners with white cars. I will ask around for you. alternatively you should make a post on www.r31skylineclub.com forums when it's up and running (should be a day or two)
my email is [email protected] if you wanna buzz me
cheers
  • 3 weeks later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
