Hi everyone,
Have not been on here for quite sometime but hope it still is a good resource for car enthusiasts.
I have a 4 wheel drive fault which logs on between 1 minute to 10 minutes after start up.
That is the 4 wheel drive turns off and light inside dash lights up.
When I turn off engine and start it again it resets and allows me to once again use the 4 wheel drive.
I have been told it could be a number of issues, but I believe it more likely is the switch or circuit that
is next to the gear box, this is apparent as it always truns off when I disengage the gears and let it roll
to a stop.
I have also been told that the 4wd needs bleeding and that can be the issue.
Anyone know what the costs are of fixing this issue...and who can do it while I wait.??????????????
I am in the north side of Melbourne and hope someone can help.
Thanks in advance,,, :)
https://www.sau.com.au/forums/topic/458051-gtr-4-wheel-drive-fault/
under the back parcel shelf you wil have the Attessa ECU. it will be throwing flash codes with a red light.
there is a manual flaoting aroudn with what they all mean,
its a pain to read. ie 4 slow flashes 2 fast then 7 slow
otherwise get it hooked up on a nissan consault
Mine was throwing ABS fault codes, Changed the module and still the same issue.
Never worked it out in the end
