Hey guys, so apparently I need a metal intake pipe as the stock plastic one is too small and can collapse under pressure with the new, larger turbo (ATR43SS). Wondering if anyone's done a DIY using silicon joiners and steel piping and would like to part any feedback. Also wondering if the return BOV and breather line are essentials ? Or can I simply make the intake, block the BOV and get a catch can to bypass the issues ? Thanks for any information.
It's on a rb25det pod filter setup
https://www.sau.com.au/forums/topic/458052-metal-intake-pipe/
Search for 'Scotty's metal intake' on these forums or PM scotty nm35. He's made hundreds, they're cheap, have all the breather and pod adapters and are great quality. I run mine on a very similar set up to yours by the sounds of things. I have pics if you find my build thread
I've spoken to Scotty, but considering he's in Melbourne and im in sydney it would be a little hard to ensure right specifications and stuff. What do you guys think of blocking the BOV and getting a catch can to get rid of the lines into the intake ?
I'm in Sydney. Seriously just get him to make it and be done with it, he's made hundreds for people on the forums, if he couldn't ensure 'the specifications and stuff' don't you think someone would have mentioned it?
His specs are spot on, all my breather lines and BOV return fit perfectly with no mods and it works perfectly. Don't make this any harder than it needs to be
Truthfully, get Scott to make one, and then alter your setup to make it fit right IFFFFFFFFFFFFFFFF it doesn't.
It will be far easier and a better solution to do it that way, and re-adjust your setup to fit the scotty pipe if there's some part that is out by 2mm here or there.
Hrm breather line and bov return needs to be cut, there's no way around it unless you use a soft intake pipe
Correct, otherwise the BOV/Breather hardpipes would somehow be inside the intake and facing the wrong angle causing AFM reversion.
I tried to make an 80mm intake that would look as stock as possible using all the stock parts. Seems to flow well too, ^^ Gregs made very good power yesterday, using the stock airbox. :)
Got your graph up yet mate? I think you made more power though one of my rb25 80mm intakes intakes than anyone before. Usually I would be suggesting a 4 inch with pod by now, but it wouldn't look stock at all. Your car is about a stealth as 400+kw gets, and it's auto... Blows my mind what Ethanol can do. :P
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
