Part list/ what has been done . Off the top of my head
Arp bolts throughout engine
5puk race clutch
Upgraded pressure plate 3400lb if I remember correct
Upgraded lighted flywheel
Single ar70 to4e garrett turbo
3inch intercooler piping
50 mm bov
N1 gtr oil pump and tomei billet gears
N1gtr water pump
Blox adj cam gears
Tomei procams 10.25mm lift
Dual stainless valve springs
1mm oversized stainless valves Titanium retainers
Stainless steel shims
Acid diped
Line bored
Skimmed and honed
3inch Full exhaust to 5inch tip
Ultra spark coils
Id1300 injectors
Bosh 044 fuel pump
2 litre surge tank setup
G4 + link ecu
5 bar map sensor
Air temp sensor
Boost solenoid
Alloy radiator
Oil relocation kit
Catch can
Front facing plenum
80mm throttle body
Top feed fuel rail
Fuel pressure regulator
CpForged pistons 9.0.1 ratio
Manley Forged conrods
Gates timing belt
Oil cooler kit
Cometic steel head gasket
New gaskets for everything
Tial wastegate
Forged crankshaft
Top mount steam tube manifold
R34 Rb26 rocker covers
Nitto clear timing belt cover
Rb25 big box
Nzkw fixed back seats
Triple cluster
Water temp gauge -electronic
Oil pressure gauge - mechanical
Oil temp gauge -electronic
Boost gauge -electronic
Top secret r33 bodykit
Bn style wide fenders
Diesal drifts 17x9 225x45x17
https://www.sau.com.au/forums/topic/458083-my-r33-build/#findComment-7564667
Thanks for advice on tials website there 50mm bov supports up to 1800hp apparently im only around the 600-700 mark on high boost so hopefully won't be a problem intercooler piping is getting the bov and air temp sensor welded in atm so no turning back now haha
https://www.sau.com.au/forums/topic/458083-my-r33-build/#findComment-7565571
