Here's what's in the FC datalogit manual
E-3-1 Anti lag ☺ (AKA Stutter box, Launch box, Pro start and “Bang bang”) ^
• Spools up your turbo for a quick drag launch o Assuming you will use the standard clutch switch (+ arming switch) ? Cut clutch switch wires
? Connect one wire through an additional (arming) switch from the standard clutch switch to terminal “SW3” on the FC-Box {FC2 FC-Box 4 Switches} Questions? Manual-GTR3233dett@fc-datalogit.co.nz 54
FC-Datalogit GTR32/33 DETT User Manual
• The additional switch is used to turn anti lag on and off (arm the system). Mount this within easy reach of your driving position
? Ground the other clutch switch wire
? Check the enable Anti lag Switch (SW3) “check box” to enable Anti lag
? Enter the amount of ignition retard you want in the “IGN Anti lag retard” text box
? Enter the amount of extra fuel you want in the “INJ Anti lag” text box
? Push the “Update” button on FC-Edit
? Turn the ignition key off and then back on
? Arm the system with the additional arming switch
? When the clutch is depressed the FC-Box will retard the ignition and add fuel to the values you have entered in the appropriate text boxes. RPMs will drop so you need to depress the accelerator to compensate. More boost will be created
? When the clutch is released the timing and fuel will return to normal
thaks maximajim,
but i thought "Antilag" which I believe Link ECU's have, is alittle different. I roughly remember reading how bad it is for the turbo life and exhausts.. I think the difference was "AntiLag" is activated straight from idle, where launch control & flat shift are induced by clutch switches, and "maybe - no expert here" are not as harmful as real "AntiLag"?
Say goodbye to your Cat converter and or motor
When you drop spark, raw fuel get's thrown through the exhaust, that pop that you hear when you get back on spark if the fuel igniting in the exhaust.....
When you drop power to your injectors, you drop fuel, big spike of detonation is possible as it leans out.  What if you miss a gear and have to clutch again......
Just a thought.
Yep, but the T-Sport one drops both at the same time. There is still some risk though. I am hoping someone else will give it crack and tell us it's all good :D
thaks maximajim,
Another method of anti-lag hold back the spark until the exhaust stoke to explode through the turbo and out the exhuast. Certainly cat/O2 sensor frying risk there.
The original Anti-lag, ie, Rally bred, actually injected raw fuel into the exhaust housing and also had a spark plug in the exhaust. This kept the turbo spinning, but didn't effect the actual combustion in the engine.
Bj,
that sounds about right, from that thread I read from some US forum. I believe the car in question (need to find that mpeg) was a blue 01/02 WRX from Western Australia running a Link ECU with proper AntiLag (eg: from Idle.. the sounds ballastic). BUT, I don't want to confuse that sort of Anti Lag with Flat shifting, or maybe I'm just confusing myself.. :confused:
surely you could just have a switch on the clutch conected to the resistor pack that is only armed after say 50km/h (or maybe arm it only when the revs go above say 6000)
then it just cuts spark when you hit the clutch (might even works as anti lag with all the fuel flowing out the zorst)
im sure its not good for it but seems very simple to do
dont know why you would want it on a road car though
  • 4 months later...
Ok so out of interest, what real world performace gain is anyone getting out of this??? Because I sware if I nail a gear change I dont loss any boost, dont hear the bov go off car keeps going etc. Say if you were that worried about loosing the boost, dont have a BOV??? Wouldnt that basically do the same thing? Im just thinking out loud atm, so dont flame me, just correct me :(
    • And if it still spikes, just for now, turn off VCT completely by disabling it OR simply unplug the solenoid. Just to rule out excessive exhaust pressure. I recall a video from Motive DVD about a decade ago, where Hawkins original single Garrett GTX3582 or so turbo had boost control issues sub 1.4bar of boost as well.   Food for thought? Is there anyway you can peg the WG completely open and/or dodgily not plumb it back into your exhaust system for testing purposes?
    • I will endeavour to give it a crack sooner or later. I have the wastegate apart at the moment so I'll replace it with a smaller spring just to see what it does and if I have to go back then so be it.   If it spikes to 23 but can then be controlled back to 20, then the gate must not be 100% open... So if it's not 100% open then why can't it drop the boost even further than 20psi (I understand it's not linear). What a headache this whole thing is.
    • Either the WG is reaching full opening, or it is not. The "it is not" case could only occur if there was not enough time available to swing the valve fully open during that boost event. I would consider that to be unlikely, as this is a commercial product that is in use elsewhere, so it really should work. But in your case, because there is definitely SOMETHING wrong, it should not be assumed that things like that are working as they should. You should put a video camera where it can see the actuator (if at all possible) during a run to see how far it is moving.
    • I think you're mostly on the ball there. With the straight gate, I suspect the weight of the spring will determine how quickly the gate can close, when not run with active pressure drive on both sides of the diaphragm. Otherwise, with drive on both sides of the diaphragm, you could almost go without a spring at all, only needing one to make sure that the thing was actually closed while completely off boost and not having pressure available to drive it closed. Butterfly valves have mostly symmetric loading when there is flow going through them, meaning that the gas hitting the upstream part of the blade is balanced by the gas hitting the downstream part of the blade, which means you don't need actuator torque to overcome any non-symmetric flow induced loads. But the gas flow does impart a purely normal load against the shaft, which transfers into the bush/bearing at each end of the shaft and does increase the torque required to make the shaft turn. Only a little, but it is there. I have no feeling for the amount of force involved in a WG application, but it certainly could make an argument for a decent spring weight being required. But all of this is just peripheral to the actual problem here.
    • The answer to this would be I followed the documentation from Turbosmart which said each spring pressure could achieve a maximum of 5x it's rated pressure so the included smallest spring being the 6psi had a range up to 30psi. I went with the 12 because I figured it'd likely hover around 15psi as a base pressure however I was obviously wrong.    I have a log here that I'll dig out that is purely wastegate and no Mac valve controlling anything.   If it can't hold anywhere near 12psi, does that mean the straight gate is virtually wide open during a run? Or am I thinking about this all wrong.   I could Tee Piece into the cooler pipe pre intercooler where the wastegate gets its feed, and send that to the ecu and see how that reads, I just don't have a spare pressure sensor currently that's all.
