Here's what's in the FC datalogit manual
E-3-1 Anti lag ☺ (AKA Stutter box, Launch box, Pro start and “Bang bang”) ^
• Spools up your turbo for a quick drag launch o Assuming you will use the standard clutch switch (+ arming switch) ? Cut clutch switch wires
? Connect one wire through an additional (arming) switch from the standard clutch switch to terminal “SW3” on the FC-Box {FC2 FC-Box 4 Switches} Questions? [email protected] 54
FC-Datalogit GTR32/33 DETT User Manual
• The additional switch is used to turn anti lag on and off (arm the system). Mount this within easy reach of your driving position
? Ground the other clutch switch wire
? Check the enable Anti lag Switch (SW3) “check box” to enable Anti lag
? Enter the amount of ignition retard you want in the “IGN Anti lag retard” text box
? Enter the amount of extra fuel you want in the “INJ Anti lag” text box
? Push the “Update” button on FC-Edit
? Turn the ignition key off and then back on
? Arm the system with the additional arming switch
? When the clutch is depressed the FC-Box will retard the ignition and add fuel to the values you have entered in the appropriate text boxes. RPMs will drop so you need to depress the accelerator to compensate. More boost will be created
? When the clutch is released the timing and fuel will return to normal
thaks maximajim,
but i thought "Antilag" which I believe Link ECU's have, is alittle different. I roughly remember reading how bad it is for the turbo life and exhausts.. I think the difference was "AntiLag" is activated straight from idle, where launch control & flat shift are induced by clutch switches, and "maybe - no expert here" are not as harmful as real "AntiLag"?
Say goodbye to your Cat converter and or motor
When you drop spark, raw fuel get's thrown through the exhaust, that pop that you hear when you get back on spark if the fuel igniting in the exhaust.....
When you drop power to your injectors, you drop fuel, big spike of detonation is possible as it leans out.  What if you miss a gear and have to clutch again......
Just a thought.
Yep, but the T-Sport one drops both at the same time. There is still some risk though. I am hoping someone else will give it crack and tell us it's all good :D
thaks maximajim,
Another method of anti-lag hold back the spark until the exhaust stoke to explode through the turbo and out the exhuast. Certainly cat/O2 sensor frying risk there.
The original Anti-lag, ie, Rally bred, actually injected raw fuel into the exhaust housing and also had a spark plug in the exhaust. This kept the turbo spinning, but didn't effect the actual combustion in the engine.
Bj,
that sounds about right, from that thread I read from some US forum. I believe the car in question (need to find that mpeg) was a blue 01/02 WRX from Western Australia running a Link ECU with proper AntiLag (eg: from Idle.. the sounds ballastic). BUT, I don't want to confuse that sort of Anti Lag with Flat shifting, or maybe I'm just confusing myself.. :confused:
surely you could just have a switch on the clutch conected to the resistor pack that is only armed after say 50km/h (or maybe arm it only when the revs go above say 6000)
then it just cuts spark when you hit the clutch (might even works as anti lag with all the fuel flowing out the zorst)
im sure its not good for it but seems very simple to do
dont know why you would want it on a road car though
  • 4 months later...
Ok so out of interest, what real world performace gain is anyone getting out of this??? Because I sware if I nail a gear change I dont loss any boost, dont hear the bov go off car keeps going etc. Say if you were that worried about loosing the boost, dont have a BOV??? Wouldnt that basically do the same thing? Im just thinking out loud atm, so dont flame me, just correct me :(
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
