Please feel free to add or correct any info. Came across this and made a few corrections already. I do not take any credit on this cause I don't have enough time on my hands to do this and I lost the link to it. I hope this helps anyone's personal decision on what turbo will work for them.
Mitsu turbos:
Mitsubishi uses TD04, TD05, TD06, TD07, TD08...to designates turbo housing.
For example, TD05H-16G 7cm^2 is a turbo with,
TD05 turbine housing with 'H' style turbine wheel. There are S, SH, H... style of turbine wheel/housing.
16G compressor wheel. 16 is the size of the wheel, 1.83 inducer, 2.37 exducer. There is no direct correlation between MHI designation and actual physical size of the compressor wheel. G is the style of wheel (uneven height of blades). C, B, T style wheel's blades have the same height. Blades are equally spaced, but the number and pitch of the blades vary between models.
8cm^2 is referring to exhaust discharge area in the turbine housing. More specifically, it is the smallest cross-sectional area of the scroll, turbine housing. Very similar to Garrett turbo's A/R. The smaller number means faster spool-up but more back pressure at higher rpm. Bigger number means longer spool up but less back pressure, thus more top end power.
Greddy modifies Mitsu turbos. I don't have any published specs for Greddy turbos and i have not taken any time to measure them. It's possible some of turbos have different specs from Mistubishi. Also, both Greddy TD05 and TD06 use 3 bolt turbine flange where as Mistubishi's uses 4 bolt flanges.
Bisides the TD04, TD05, TD06, TD07 and TD08 turbos, Greddy also makes hybrid turbo, T67 is TD07 compressor and TD06 turbine, same turbo as TD06SH-25G. T78 is the compressor of TD08 and turbine of TD07, T88 uses compressor and turbine from TD08.
Garrett Turbos:
Garrett basically has two lines of turbos. The ancient, inefficient T series turbos and the new, modern, ball bearing GT series turbos.
T family has T22, T25, T3, T350, To4B, To4E, TS04, To4R ...These are 50 year old, WWII generation turbos.
The newer line of GT turbos are ball bearing on journal and thrust bearing. The turbine and compressor wheels are improvely aerodynamically to flow more air. GT20, GT22, GT25, GT30, GT35, GT40, GT45, GT50... GT turbos produce slightly more hp then older T series turbos with the same number designation. A GT Garrett turbine wheel wil flow more air than similar sized Greddy turbine wheel. Thus GT turbos are able to boost higher and flow more.
Turbonetics and many domestic makers turbos based on T series turbos. A T3/To4E 60 T .63A/R is a hybrid turbo with T3 turbine, To4E compressor, 60 Trim compressor wheel and .63 A/R turbine housing.
Wheel "trim" refers to the squared ratio of the smaller diameter divided by the larger diameter times 100. Generally, the larger the trim number the more flow the wheel has.
For compressor wheels , larger trim tends to mean slightly lower efficiency.
For "families" of turbine wheels (those with the same inducer diameter), larger trim usually means better flow with less backpressure but longer spool time.
A/R is a ratio of the exhaust discharge area vs the distance from the center of turbine wheel to the center of the cross sectional area. Smaller A/R housing has faster spool up. Bigger A/R housing has less back pressure, more flow for the top end.
The so called "T-series': T60, T61, T66, T70, T72, T76... are T4 turbos as well. The number means the compressor inducer size. ie: T76 means it has 76mm compressor inducer.
HKS uses Garrett turbos. HKS GT series turbos use Garrett GT's turbine with GT's compressor.
For example, HKS GT 2835 is GT28 turbine with GT35 52 trim compressor.
The newer line of Garrett GT-R turbos are hybrid turbos. For example, GT30R is a hybrid of GT30 turbine mated to 56 trim GT37 compressor.
Flow Rates @ 15psi:
TDO4-9B-6CM2 265 CFM
TDO5-12A-8CM2 320 CFM
TDO4-13G-5CM2 360 CFM
TEO4-13C-6CM2 360 CFM
TDO4L-13G-6CM2 360 CFM
TDO4L-15C-8.5CM2 390 CFM
TDO5H-14B-6CM2 405 CFM
TDO5H-14G-8CM2 465 CFM
TDO5H-16G-7CM2 505 CFM
TDO5H-16G-10CM2 505 CFM
TDO6-17C-8CM2 550 CFM
TDO6H-20G-14CM2 650 CFM
TDO7S-25G-17CM2 850 CFM
TFO8L-30V-18CM2 1200 CFM
Max Output:
TD05-14B (stock 1st gen) 275-300hp @ 21 psi
TD05-16G (small) 345-365hp @ 22 psi
TD06-16G (large) 365-385hp @ 22 psi
TD06-20G 430-450hp @ 22 psi
T25 (stock 2nd gen) 235-250hp @ ?? psi
T3 (super 60)/T2.5 hybrid 265-280hp @ ?? psi
T3 (super 60)/T2.8 hybrid 270-320hp @ ?? psi
Evolution 1
Turbo = TDO5H–16G-7
Nozzle Area (cm2) = 7
Exhaust turbine = Inconel (steel alloy)
Compressor = Aluminium, 60mm wide
Evolution 2
Turbo = TDO5H–16G-7
Turbine = Inconel (steel alloy)
Evolution 3
Turbo = TD05H–16G6-7
Compressor = Aluminium, 68mm wide
Evolution 4
Turbo = TD05HR-16G6-9T
Nozzle Area (cm2) = 9
Evolution 5
Turbo = TD05HR-16G6-10.5T (GSR)
TD05HRA-16G6-10.5T (RS)
Nozzle Area (cm2) = 10.5
Turbine = Inconel (steel alloy), Titanium alloy (RS)
Evolution 6
TD05HRA-16G6-10.5T (RS/rs2)
Turbine = GSR - Inconel (steel alloy), Titanium alloy (RS/RS2)
Evolution 6 : Tommi Makinen Edition
Turbo = TD05RA-15GK2-10.5T (GSR)
Turbine = Titanium alloy for both RS/RS2/GSR!
Compressor = Aluminium, 65mm (gsr) - 68mm(rs) wide
Evolution 7
Turbo = TD05HR-16G6-9.8T (GSR)
TD05HRA-16G6-9.8T (RS/RS2)
Nozzle Area (cm2) = 9.8
Turbine = GSR - Inconel (steel alloy), RS/Rs2=Titanium alloy
Evolution 7 GTA
Turbo = TD05-15GK2-9.0T
Nozzle Area (cm2) = 9.0
Compressor = Aluminium, 65mm wide
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM E
Turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
RS/Rs2=Titanium alloy.
All Evo 4-8 Turbos are twin scroll designs meaning that the engines exhaust is divided into two channels (see first pic). As the engine exhausts in pulses.. its supposed to result in quicker spooling. From the Evo 4 onwards, the Turbo spins in the opposite direction, i.e. Anticlockwise (hence the R in the turbo name). The Titanium Alumnide alloy used in the RS/RS2 and some GSRS (factory option) has less inertia and thus spins up around 500 rpm sooner. These Titanium turbos can be indentified by the A in their name.
Mitsubishi:
16g = 34lb/min
Big 16g = 36lb/min
EVO III Big 16g = 36-40lb/min (DSMLink has logged several 40+) NEW!!!
20g = 44lb/min
Forced Performance:
Big28 = 37lb/min
FP2544 = 44lb/min (56trim/ dual BB)
Sleeper 16g = 44lb/min
Green = 49lb/min (50 trim)
FP49 = 49lb/min (50 trim, T31 turbine)
Red = 60lb/min (60-1 trim, dyno 520whp)
FP3052 = 52lb/min (dyno 504whp)
FP3065 = 65lb/min (dyno 585whp)
FP58 = 65lb/min (GT40 56 trim comp. wheel, .49A/R PTE, T350 turbine)
AGP:
T28 = 36lb/min (TB03 compressor)
RS43 = 43lb/min (46 trim T04E)
SS44 = 44lb/min (It is a 44lb/min but not a 48trim. It is not a GT30 at all. It’s special, topsecret, Kevin)
RS49 = 49lb/min (50 trim T04E)
RS60 = 60lb/min (60-1 trim) (claimed 534whp)
RS65 = 65lb/min (56 trim GT40)
DSM Performance/Extreme Turbo:
ETA12 = 36lb/min (S-trim, ETA comp housing)
ETA32 = 48lb/min (50 trim, ETA comp housing)
ETE32 = 48lb/min (50 trim, T04E comp housing)
ETE42 = 50lb/min (60 trim, TO4E)
ETE52 = 55lb/min (60-1 trim, TO4E)
ETE53 = 55lb/min (60-1 trim, T04E) NEW!!!
ETE73 = 72lb/min (T66 comp wheel, T04E) NEW!!!
Buschur Racing:
BR-BIG28 = (claimed 350hp) NEW!!!
BR20G = (TD05/6 hybrid, first in 10s)
BR475 = (No info as of yet) NEW!!!
BR57 = (Garrett T3/T4)
BR500 = (claimed 504whp)
BR580 = (claimed 575whp)
BR675 = (No info as of yet) NEW!!!
Slowboy Racing:
SBR-M50 = 48lb/min (50 trim)
SBR-M60 = 60lb/min (60-1 trim)
SBR-GT10 = 44lb/min (48 trim, dual BB)
SBR-GT11 = (No info as of yet) NEW!!!
SBR-GT12 = 55lb/min (56 trim, dual BB)
SBR-GT13 = 60lb/min (60 trim, dual BB)
SBR-GT14 = 65lb/min (56 trim, dual BB)
SBR-GT35R = (No info as of yet) NEW!!!
SBR-GT30R = (No info as of yet) NEW!!!
SBR-G50 = 48lb/min (50 trim, T04E) NEW!!!
SBR-G57 = 55lb/min (56 trim, T04E) NEW!!!
SBR-60-1 = 60lb/min (60-1 trim, T04E) NEW!!!
Frankenstein Turbos:
Frank 1 = 46 trim, 20*clipped TD05H turbine, TD05H 7cm2 housing
Frank 2 = 46 trim, unclipped TD06 turbine, TD05H 7cm2 housing
Frank 50 = 50 trim, unclipped TD06 turbine, TD05H 7cm2 housing
Frank 3 = 54 trim, unclipped TD06 turbine, TD05H 7cm2 housing
Frank 57 = 57 trim, unclipped TD06 turbine, TD05H 7cm2 housing
Frank 4 = 60 trim, 10*clipped TD06 turbine, TD05H 7cm2 housing
Frank 5 = 60 trim, unclipped TD06H turbine, TD05H 7cm2 housing
Frank 6 = 60 trim, unclipped TD06H turbine, TD05H 8cm2 housing
Frank 7 = 60 trim, 10*clipped TD06H turbine, TD05H 8cm2 housing
GT30 (ball bearing) turbos:
48 trim = 44lbs/min
52 trim = 50lbs/min
56 trim = 55lbs/min
60 trim = 60lbs/min
gt35 trim = 65lbs/min
Garrett:
T-28 = 34lb/min (350BHP)
50 trim = 47lb/min
57 trim = 49lb/min
60-1 = 65lb/min
The following is from Turbonetics Catalog:
On TO4E Compressor housings:
50-trim = 47lbs/min
54-trim = 45lbs/min
57-trim = 49lbs/min
60-trim = 50lbs/min
T-100 = 180lbs/min
TO4B compressor housing:
60-1 = 65lbs/min
62-1 = 70lbs/min
Compressor Turbine comp avg Trim Inducer/ Minor Dia. Exducer/ Exducer/ Inducer/ Trim Major Dia. Minor Dia. Major Dia.
TD04-09B 50 1.365 1.93 1.55 1.86 1.6475
TD04-13G 62 1.58 2 1.625 1.812 1.79 T3 35 1.396 2.367 1.8815
TB02 22 1.56 1.989 1.517 1.833 1.9015
TD04H-15C 1.638 2.165 1.743 2.028 1.9015
TD04-15G 55 1.625 2.187 1.625 1.812 1.906
TD04H-15G 55 1.625 2.187 1.74 2.047 1.906
Mk 4 CT-12 1.535 2.283 1.732 2.047 1.909
T3 40 1.484 2.367 1.9255 T3 45 1.595 2.367 1.981 TD05H-14B 55 1.695 2.285 1.93 2.2 1.99
TD05-16G 1.814 2.223 1.911 2.184 2.0185
T3 50 1.674 2.367 2.0205
TD05H-14G 62 1.8 2.285 1.93 2.2 2.0425
TD04-17G 54 1.744 2.382 1.625 1.812 2.063 T3 55 1.76 2.367 2.0635
TD05H-16G 60 1.83 2.365 1.93 2.2 2.0975
TD04-18T 1.625 1.812 T3 60 1.83 2.367 2.0985
GT2510 63 1.86 2.344 1.626 2.067 62 2.102
GT2530 63 1.86 2.344 1.883 2.098 76 2.102
T3 Super 60 1.9 2.367 2.1335
Mk 3 CT-26 1.811 2.559 2.047 2.677 2.185
TD05H-16G 50 1.892 2.68 1.93 2.2 2.286
TD05H-18A 50 1.9 2.68 1.93 2.2 2.29
TD05-18G 1.97 2.652 1.911 2.184 2.311
T04B S 1.904 2.75 2.327
TD05H-18G 55 1.992 2.68 1.93 1.93 2.336
GT2835 48 1.923 2.773 2.02 2.204 84 2.348
TD06-20G 2.051 2.652 2.149 2.535 2.3515
TD05H-20G 60 2.07 2.68 1.93 2.2 2.375
GTRS 52 1.997 2.773 1.833 2.098 76 2.385
GT2835 52 1.997 2.773 2.02 2.204 84 2.385
T04B T 5/6 2.032 2.75 2.391 GT35 52 2.016 2.795 2.453 2.677 84 2.4055
T04E 40 1.87 2.95 2.41 GT2835 56 2.071 2.773 2.02 2.204 84 2.422
GT2835R 56 2.071 2.773 2.09 2.204 90 2.422
T04B Super S 1.904 3 2.452 T04B V 2.18 2.75 2.465
T04E 46 2.003 2.95 2.4765 GT2540 46 2.016 2.972 1.833 2.098 76 2.494
GT3037 48 2.059 2.972 2.145 2.34 84 2.5155
T04B H 2.298 2.75 2.524 GT3037 52 2.145 2.972 2.145 2.34 84 2.5585
T04E 54 2.17 2.95 2.56
HKS T04E 57 2.196 2.925 2.266 2.785 62 2.5605
T04E 50 2.122 3 2.561
GT37 52 2.157 2.992 2.614 2.854 84 2.5745
GT35 2.157 2.997 2.453 2.677 84 2.577
T04B Super V 2.18 3 2.59 T04E 57 2.23 2.95 2.59 GT3037 56 2.223 2.972 2.145 2.34 84 2.5975
T04E 60 2.29 2.95 2.62
HKS T04S 60 2.301 2.972 2.523 2.894 76 2.6365
T04B Super H 2.298 3 2.649 T04B 60-1 2.324 3 2.662
T04B 62-1 2.441 3 2.7205 GT3040 50 2.262 3.198 2.145 2.34 84 2.73
GT40 50 2.283 3.228 2.591 3.031 73 2.7555
GT3240 54 2.352 3.198 2.106 2.289 84 2.775 GT37 2.327 3.228 2.614 2.854 84 2.7775 TS04 (T-57) 2.3 3.304 2.802 HKS T04R 63 2.601 3.276 2.523 2.894 76 2.9385
T-61 2.382 3.544 2.963
HKS T04R/GT63 GT63 2.626 3.307 2.547 2.921
GT76 2.998
GT40 54 2.547 3.465 2.547 3.031 84 3.006
T-78 GREDDY 2.598 3.543 2.559 2.913 3.0705
T-88 GREDDY 33D 2.598 3.543 2.846 3.346 3.0705
T-64 2.49 3.67 3.08
T-66 2.58 3.584 3.082
HKS T51 KAI 56 2.742 3.666 2.785 3.198 76 3.204
T-88 GREDDY 34D 2.744 3.74 2.846 3.346 3.242
T-70 2.72 3.85 3.285
T-72 2.84 4.03 3.435
GT42 53 2.925 4.016 2.961 3.228 84 3.4705
HKS T51 SPL 56 2.984 3.986 2.785 3.198 76 3.485
T-76 3.02 4.03 3.525
https://www.sau.com.au/forums/topic/458100-turbocharger-specs-and-sizes/
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
