Hi all,
Doing a turbo install which led to all my coolant in the engine being drained out. How would I go about refilling this? I can't start the car and run it waiting for the thermostat to open as there's no coolant to heat up.
Would my best option be to remove the thermostat and just have a bit of straight hose connecting my radiator to the car?
If so
How would I go abouts putting the thermostat back in without covering myself in coolant and loosing a majority of it?
Thanks
Actually does the thermostat need to be open to refill the engine with coolant or will it still flow in the engine 1 way with it being shut? I thought that it wouldn't matter but my coolant bottle is still showing Max when I've drained the block which has just confused me. Help would be greatly appreciated !
Just pour coolant in like normal, most thermostats have a small air bleed hole.
When your warming up the car, the thermo will open, water level will drop and you add coolant.
Then follow the standard bleed procedure, open the bleed nipple when hot to purge out any air pockets in the head.
Should all be in the workshop manual.....
Dude i know you're new but come on, there's like 20,000 threads on draining/flushing coolant. Download workshop manual as above, its pretty straightfwd and you don't need to remove thermostat.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
