ahhhh the Bee R B5 is on my wish list. Always wanted a set. 18x9.5 +25. I've had this link bookmarked for years lol.
http://www.bee-r.com/main/parts/wheel/index.htm
meh to meisters. They played out. Same with professors. Just my opinion.
Edited by JTCC
Not trying to be snobby. But I would never buy rotas. I like the real stuff, plus they look like cheap junk compared to real wheels. But I am a bit of a wheel whore. That's just my opinion. Once you are used to a certain quality, its hard to down grade. Probably the same reason I have never bought a stainless steel exhaust lol. First exhaust I ever bought was titanium...... never looked back lol.
Edited by JTCC
Neither would I if I had my time again but I was young and it was all I could afford.
Mind you I've been racing on them for a few years now and the only issue I've had is the paint bubbling due to heat.
Ironically enough the first wheels I bought were factory r32 gtr wheels lol about 10 years ago. Still have them. Then I bought bigger brakes, which means they no longer fit lol. So then I bought some super advan racing ver 2 in metallic blue. Unboxing those after a 6 month wait was awesome. They look way better in person than in pics. I have had a lot of people say that now that they have seen them in person, it's one of the coolest wheels they have ever seen. It's certainly one of my favorites. I like a lot of advan stuff though.
I havent even begun yet guys lol. Some of this stuff I've had for years just laying around. This was my plan, to make my own nismo GTR. But with better parts in some areas where nismo is lacking. Also keep in mind, I've only physically had the car for less than 2 weeks.
Ok since we were discussing wheels, this will seem fitting lol.
Advan AD08R 265/35/18
Advan RG original. 18x9.5 +12. I now know why they called these GTR sizes. They are PERFECT. Slight fender roll needed. More like a massage.
Car still up in the air
One side on, back on the ground. Looks WAAAAY better and more aggressive.
Here is the side with 17x9 +22 TE37 with 255/40/17 nankang ultra sport NS-II for comparison.
Back shot of TE37
Front of TE37, you can see they are slightly sunk in
Rear of the Advan RG, perfectly flush, needs a fender roll
Front of RG, you can see it pokes where the TE37 were sunken battleship status.
I am a huge Advan fan. They just look better than so many other manufacturers. The quality is great. I am still not that impressed with rays or volk. They are quality, but even looking at these TE37 they don't stand out much. There is no attraction. My second set of advans and I am equally impressed. Just my opinion.
Edited by JTCC
  • Like 1
Not sure on the spring rates. Whatever HKS hipermax II came with I'm assuming. They are decently stiff when driving. The rears are not close really, you just need to roll the inner lip a bit. The lip sticks in, where as the wheels are inline with the actual surface of the quarter panel. They rub on hard cornering and bouncy areas of road. All 4 corners rub on bouncy areas. I'll look at it more tomorrow, was getting to dark. Should be fine with basic fender roll. I think that is actually how they were designed to be put on. Unless you want a 4x4 GTR. I am also not sure on my alignment specs. I'm sure a degree or two of camber would probably clear them as well. But as soon as I put them on....you just got that feeling like "oh yea, these are the ones" lol.
Edited by JTCC
  • Like 1
I personally love the square tyre sizing with 265's on 9.5 wide.
but you could always go a bit narrower with 245's for a bit more squeeze but given your rolling/alignment adjustments shouldn't be an issue.
Ok another update. Did a slight fender roll, didn't even have to roll them completely. Fits like a glove now. No rubbing at all. Also we put the exhaust on. We didn't do the turbo dumps because it was a little more involved than we had planned. So we just did the the fronts pipes on back. Midori Seibi is incredible. Fits like a glove. Looks amazing, sounds amazing. I can't describe it. The front pipes really open up the exhaust. Can hear the turbos spool very well now. Definitely notice a power boost. Feels really good. The sound is so clean and crisp. It's just.....yea.
Midori Seibi 90mm full titanium exhaust setup.
  • Like 3
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
