Hi, I spent a few minutes after work making this video: -
https://vid.me/SsST (very prominent)
https://vid.me/TXKc (pulling off a little more quickly)
It's reproducing an issue that I'm having with my car right now which sounds horrible.
Basically, whenever I pull away in first, it usually (more so when pulling away very very gently), makes that horrible scraping sound. That's a particularly bad sounding one as I attempted about 20 times to get the worst sound one that it makes and tried to prolong it.
The clutch is a triple plate clutch greddy and has no problem holding a lot of power, as you would imagine a clutch like this could, and can launch without problems just fine. I hardly ever launch it but I did a few lately just to test for any issues and it was fine.
I spoke to one of the guys who's worked on my car before and I was told that it was probably just an unsprung clutch and that the sound was not a problem, as long as I could put up with how horrible it sounds. I'm beginning to think it's a bit more than that though and possibly a throw out bearing? The clutch behaves like most triple plates and makes the funny rattling sound when the pedal is pressed in.. that's cool, I actually like that noise. I think it's getting worse though and I need to take it somewhere but I would love to know what you guys think!
My car makes the same sound, been told its probably a button clutch. Had the car for 3yrs no issues with the clutch other than that god awful sound. Not sure what clutch is in it though. It's stood up to a decent beating here and there too so dont think theres anything wrong. I'd be interested to hear what more knowledgeable people think though. Good luck.
Edit: Button clutches don't like to be rode whereas a normal clutch you can ride it a fair bit (still shouldn't but you can). I guess that's why on faster take offs they don't make the sound as much.
Ah right, so it's just because I've got a ridiculous clutch.. that's ok then.
It definitely only occurs when slipping the clutch; if I launch or pull of spiritedly, it's like a dream!
Edited by edizio
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
