Reason for sale is now living⁄working in NSW and don't require a car. I Will be in Hobart between the dates of 17th-19th of July if you would like to inspect!. The car will also come with 22k worth of receipts as well as a Nissan Skyline R33 Gts-t manual and car cover with clamps.
REGO Expires 12⁄03⁄2016
193,000km on Chassis⁄body
290rwkw with dyno sheet at 18psi (tune done by Autocraft)
ALWAYS ran and tuned on BP98 since engine rebuild
Serviced every 5000kms using 5w-30 Castol Edge
Engine specs⁄modifications:
RB25 reconditioned block with CP pistons (less than 10,000km)
RB25 reconditioned head (standard head) (less than 10,000km)
Garrett 3076r T3 flange turbo (less than 15,000km)
6 Boost high mount manifold (less than 15,000km)
Exedy Cushion button cluth (less than 15,000km)
Greddy *replica* forward facing plenum (less than 10,000km)
80mm throttle body (less than 10,000km)
HKS Fuel Rail (less than 10,000km)
ID1000 injectors (1000cc) (less than 10,000km)
2x Davies Craig 10” Thermatic Electric Fans
Trust front mount intercooler
Aftermarket alloy radiator
Nismo Engine Mounts (less than 10,000km)
Turbosmart Pro-gate50 external wastegate with screamer (less than 10,000km)
3” Turbo back exhaust with hi-flow cat
Haltech Plug-in Pro ECU
GFB G-Force 2 Electronic Boost Controller
Turbo timer (cut's engine if car is moved whilst counting down with key removed)
Bosch 040 fuel pump
New OEM clutch slave cylinder replaced
Unopened OEM clutch master cylinder
Splitfire coilpacks
SARD Fuel pressure regulator
Exterior⁄interior modifications:
Yellowspeed Coilovers
Ultrex engine bay strut brace
18x9.5 +20 Rota Grid-r gun metal grey rims
Alpine CDA head unit (3 pre-outs)
Alpine MRP-M500 mono block AMP 500w RMS
Alpine Type R 12” Subwoofer
Alpine Type S 6x9 Rear Speakers
Pioneer Front speakers
Sony Xplod XM-604EQX 4 channel Amplifier
Short shift kit
Cyclops Alarm ‘Remote alarm deluxe’
Custom boot floor and carpet made
BAD bits
Driver’s side seat needs work where constant rubbing occurs from entering and leaving the seat.
Tune needs idling adjustment for hot start
Front bar requires work (paint and fabrication) (has been strengthened on all weak points of bar, before and after photo included)
Looking for cash only thank you.
If you are interested I (Beau Rogers) can be contacted on 0488 nine53 twotwo4. Best to send me a text rather than call as my working hours can be very eratic (usually busy 5am-6pm)
Feel free to ask any questions about this vehicle
This is a short video of how the car sounds (private road)
https://vid.me/tc2o
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
