Just got my first gtr and went to change the air filter and saw that it has oil around the rim and the air flow meters have oily residue on then and pipes leading to turbos had some oil in them .
Can this cause problems with the turbos if they have been sucking in the oil???
Any help would be appreciated .
https://www.sau.com.au/forums/topic/458176-oily-air-filter/
I'd spend the time to pull all the turbo side piping off from intake to inter-cooler to have a look and see how much gunk and shit has been collected and might be worth cleaning it all up.
Obviously the lowest points in the pipework will collect/pool all of the oil over time.
As Hadouken said, you should invest in a Catch Can. Preferably one that will work and not just put the shit back into your intake if you plumb it back, or send it to an external filter.
https://www.sau.com.au/forums/topic/458176-oily-air-filter/#findComment-7566687
