Hey Guys,
Been looking at R34 GT-R's lately.
Saw this one for sale for a while now,
http://www.carsales.com.au/private/details/Nissan-Skyline-1999/SSE-AD-2284409/?Cr=2
Anyone know anything about it ?
It's done extensive work to it and priced pretty low considering and its a V-Spec aswell.
Thanks
https://www.sau.com.au/forums/topic/458178-r34-gt-r-australian-market/
Why an engine rebuild within 15,600Km?
Bet you it spun a bearing.
Now the scary thing is who built the engine and if it did spin a bearing did they machine or use a new crank.
Hahaha i think that he's saying that it was "CHASSIS HAS DONE 75,000 Km, ENGINE HAS DONE 15,600 Km"
So the KM represents the KM since the engine rebuild.
Ah. So The original engine lasted 60,000. ?
I'm going nuts over this same issue :wacko: . I miss my GTT too much so I've been looking at a 34GTR vpsec for the last few months.
Last option is to import one.. But as you guys can imagine I'm gettin a lot of resistance from family and friends saying dont spend so much on an old car.
Also I heard rumours about govt dropping import duties since the aus car manufacturers are shutting down their plants.
Will the 34GTRs retain their value? How much should I be spending on a clean one? I'm only lookin at V-spec and above. Preferably blue. :woot:
What I have noticed,
34's have started to drop in price. Average price of one that looks nice $40k.
And I dont know what is going on with the market but 33's and 32's are now going up.
I dont know if people are getting close to the asking price for their cars but if the whole market is demanding xxx then they will receive xxx.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
