Hey guys
Currently making 415rwkw with a gtx3582 .82 rear housing on 27-28lb boost. What's the best way of getting close to or over 500kw? Would a bigger rear housing suffice ? If not what turbo is the next logical size up. Running a forged motor with all Nitto gear. Currently out of fuel system (single walbro 460lph) so couldn't push more , ill be adding two extra 044 fuel pumps into the mix
Edited by Gta51
https://www.sau.com.au/forums/topic/458183-500kw-rb25det/
Would the biggest size tomei poncams help boost it aswell? fairly sure I have stock cams in it atm.
Cars a street car so I want to stay away from nitro meth etc loll
Im thinking a 1.06 rear housing, cams, and abit more boost should get me close to that
https://www.sau.com.au/forums/topic/458183-500kw-rb25det/#findComment-7567193
If you have a GTX35 and only making 400-420rwkw though @ 27-28psi you've kinda got a problem... Assuming you are on E85 as well.
Should be a bit more than that. A GT35 will do 400rwkw on E85 with that amount of boost. The GTX flows more air, it should be well past it and around 440rwkw or more.
Could be a restriction somewhere or something else entirely. I'd be working out what is wrong first before going for more power/part changing.
https://www.sau.com.au/forums/topic/458183-500kw-rb25det/#findComment-7567818
But a 500kW turbo LS is a very much more "streetable" engine than a 500kW 2.5 L RB!!
It's funny when the "400-500rwkw" street guys get asked what MPH they run, quite often it's FAR lower than what it should be.
Proof is always in the pudding there :)
  • Like 1
https://www.sau.com.au/forums/topic/458183-500kw-rb25det/#findComment-7567915
So agree with nismoid.
I remember a long time ago when this wasn't the case.
Ahh the good old days when saying you had a fast car actually meant, ummm, you actually had a fast car.
Mph will always rule the roost.
most cars cant handle it... we have high 300 cars running 9-10 then 500kw cars running 10-12s lol.... MPH is no longer an accurate SOLE indicator
perfect example
  • Like 1
https://www.sau.com.au/forums/topic/458183-500kw-rb25det/#findComment-7567977
Stock cams and a single fuel pump limited me. Once I add another pump and cams I'll see that figure with a retune I'm fairly sure. I get what your saying though :)
Edited by Gta51
https://www.sau.com.au/forums/topic/458183-500kw-rb25det/#findComment-7568060
perfect example
Yeah but in GTS-t / GT-R land - There are so many results it's pretty easy to work it out where a car should be (say +/- 3/4mph). Some cars are like 10mph down (some are up lol), that ain't a result of a car that can't handle the power. Generally from what I've seen, if you have less traction you end up with slightly higher MPH - big more bragging rights at the pub isn't necessarily a bad thing lol :)
Most R33 GTS-t owners with 300-340rwkw are around the ~127mph
R33 GT-Rs with 300-340rwkw get around the ~124mph, if it's a R32 you're a little higher as you weigh less and so on.
Of course it's never gonna be 100% accurate, but you can get in the ballpark. Same as when someone posts up their GT-R is making 370rwkw on -9s never got anymore than like 120mph... Result debunked, you didn't have 370rwkw! Not a chance.
Then there was a 450rwkw 33 GT-R recently in NSW I saw that I think was like 124/125mph. Even without doing a big launch, something ain't right, it should be over 130mph easy.. Either it didn't have the power on the night or someone was singing hey diddle diddle in the dyno room
  • Like 1
https://www.sau.com.au/forums/topic/458183-500kw-rb25det/#findComment-7568089
I had a big post for ya and my internet died lol. Poop.
Anyway I think fix the fuel pump and then see? It's pretty easy to do... IMO you should've run outta fuel before you got to 28psi. That's a LOT of pressure/flow needed outta the pump. Guys here on PULP have made ~370rwkw with a GT35 and stock RB25 head (around the 22psi marker). Then to get the 400 E85 and a bit more boost, and that's a smaller huffer and you really are running some good boost.
I mean look it might be nothing, or maybe you'll find 30rwkw easy just getting the fuel it needs? Even something simple like dropping the exhaust at the dump/cat you might just pick up 30rwkw. Sometimes even with a little restriction a set-up can still perform very well, just not perfectly type thing.
Obviously with head/cams etc you will potentially make more but something currently just doesn't sound right if you know what I mean? I'd be sorting the bits around it and checking a couple things first if you haven't already
https://www.sau.com.au/forums/topic/458183-500kw-rb25det/#findComment-7568097
perfect example
https://youtu.be/Po10g8VGKTI
ETs have always indicated setup, MPH have always indicated power
Nothing has changed.
Dynos lie, MPH don't.
  • Like 1
https://www.sau.com.au/forums/topic/458183-500kw-rb25det/#findComment-7568099
Spot on fuel pump was the biggest limiting factor for me. So I'm going to add another Walbro or two 044 pumps. Might aswell add cams since I'm getting retuned, always wanted to do that anyway
https://www.sau.com.au/forums/topic/458183-500kw-rb25det/#findComment-7568108
    • That M3 looks like it handles so well, initial slight understeer on turn in followed by oversteer which is cancelled out as steering returns to centre. Looks like such a fun car to drive. In comparison the Skyline and Sierra look like they understeer more and thus need more heavier steering inputs...?
    • Gday   on the hunt for an rb25 gearbox and clutch to go into my R32 rb25/30 build happy to travel a bit or pay for freight for the right one From my limited research, think I need an rb25 driveshaft yoke to make it fit so I’m after one of those too located Bathurst
    • Common for single gauges to be swapped around. My 33 GTST when I bought it had a GTR tacho fitted, everything else was GTST gauges.
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
