ETs have always indicated setup, MPH have always indicated power
Nothing has changed.
Dynos lie, MPH don't.
Power and setup will make a difference in MPH
For example if we have 2 cars with 450awkw, one with -5's and a dog box and one with a Gt42 and standard gearbox with a clutch that won't shift at high rpm the car with the -5 will trap higher obviously.
The guys with the 500kw dyno graphs trapping 125mph very well could have that power but might not have the tyres, clutch, gearbox, powerband, driver to use it properly.
^---- that is the truest of all.
Other numbers, lap times. It's all just numbers. It's all just some kind of respresentation of some aspect of the car. You can think of the drag strip as either an "advanced dyno" or a reason to live.
  • Like 1
Agree to disagree.
Statistically speaking a 300kw a gtr should trap at 120mph approximately. So when talking of any other cars with similar weights they are always in the ball park with a half decent setup for traction and drive line.
The big variable is usually ET, but mph is always there or thereabouts.
So the reason there MPH is down to mechanical issues there, easily explained and logical. :thumbsup:
I went from a Ppg dog box 400rwkw setup that trapped 131 to a standard box slowly shifting with a easy launch down to 126mph exact same power.
Just saying there's a bit more to it then rolling out with a certain hp and running X mph.
No 100% correct.
same car 2 different tyres *10-15mph difference... same day same driver. Changing from 215 nankangs to 255 et streets didnt magically make any more power.
Gone are the average days of a bit of spin then grip enough to cross the line.... half the "average" turbo cars nowadays will powerskid 400m no sweat... and cross the line way off the optimum MPH.
  • Like 2
Agree to disagree.
No 100% correct.
As I said in the post above. A half decent setup for traction and driveline will see mph there or thereabouts. This means a good set of tyres at least obviously.
My point being, if someone quotes a dyno figure, then the next question is what mph did it run. If its lower than the expected range with a fair 1/4 mile run, then the power level needs to be questioned.
Well that's the way I have always confirmed my cars and everyone I know does the same thing.
So in the case above did the final mph support the dyno numbers?
Same goes for running semi's on a roller dyno and strapping the car down hard, no-one will be interested when you run 50kw less than your projected output.
Some cars are setup for drag and some aren't. It's less reliable than the dyno figures you are trying to prove misleading imo.
^ thats a fair call.
BUT what you are missing if you just take off normally at a drag strip your MPH will still be similar at a given weight/power ratio.
Doesn't matter on setup and if you are in a GTR you will have traction unless you are running silly power and really poor rubber.
That is how the online MPH calculators work and they are pretty good.
DISCLAIMER: This doesn't take into account bad driving etc.
Remember doesn't matter if you win by an inch or a mile.
Edited by Stixbnr32
  • Like 1
So did you not read Ryan1200's post a few up about exact same power, just different gearbox and 5mph difference??
So it does matter on set up etc and is not just all about what power you run.
Your online calculator can't take differences like a dog vs normal H pattern into account.
More to it than X power runs X mph
Edited by tricstar
With manual gearboxes.... Power under the curve drastically changes mph,not just the peak , with autos because the converter setup properly is spinning the motor in its sweet spot constantly
its easier to use mph vs power.
Its still a good marker regardless...many problems have been found at a dragstrip vs a dyno due to mph being off. Boostleaks are a big one. A car will run hard to 1/2 track and drop
mph big time in the back half.
cheers
darren
Yeah but then we are talking ratios and driver performance (slow gear changes) if you are changing gearboxes.
Lets not get into that - we all know a seq can change quicker than a H pattern and you will most likely end up with higher MPH.
I know I have contradicted myself here a little but lets compare apples with apples.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
