Hi All,
I have a bit of an issue I can't put my finger on and I am hoping the SAU community can help.
I recently imported a 33 GTR and when I drive the car and keep it at a steady 3500 rpm there's a miss. Below and over 2500 rmp the car runs ok. Having said that the fuel consumption is very bad and there's plenty of back fire in normal driving.
I have done my home work and searched on this site and Google and the below have been helpful but not solved my issue.
What I have done:
  • Changed spark plugs to NGK BCPR7ES which I chose after reading a thread on SAU
  • Changed the fuel filter
  • Changed the CAS
  • Changed the pod filters to airbox
  • Changed AFM
  • Changed BOV's and checked piping was on tight
  • Changed the coil packs and sealed them with dielectric goo as the YouTube video suggested
The car sounds a little rough on idle but I am not sure if this is because the cam timing as the in was set to 0 and ex 2 degrees retarded. I noticed this when I did a full service on the car and I changed my timing belt. HKS cam gears came as a surprise. (the car was missing before the service)
The only thing I haven't changed is my injectors and fuel reg as one of the topics said that possibly could be the issue.
Before I start removing the fuel rail, injectors and reg is there anything else that could be causing this issue?
All your input will be greatly appreciated as I am stumped!
Thanking everyone in advanced.
https://www.sau.com.au/forums/topic/458193-r33-gtr-missing-at-3500rpm/
Most likely a vacuum/boost leak.
Last time i had a miss it was the igniter module, in my case it was above 3500 but sounded like the wide spark gap or faulty coil pack issue.
In your case with backfire it sounds more like a Vacuum or boost leak, you need to check your hoses and pipes first.
Thanks guys!
I think you might be right about the vacuum leak as I believe the brakes are not as good as they should be. I have found a workshop that has a vac leak tester (think it's called a smoke test) and have a booking on Monday.
Having said that though I used carby cleaner and sprayed around hoses but I didn't notice anything.
Will keep you posted on the results/ solution.
Edited by manage13
Dead or failing o2 sensors do all those things...
Hi Trent,
Thanks for your response. Does the engine light come on when an 02 sensor fails? Currently I don't have the warning light. Also, if I plug a diagnostics tool will I be able to tell if the O2 sensor is failing?
Thanks.
.. r33 GTR missing at 3500rpm!
2 questions:
- Where did it go? I assume it came back/
- Do you have a picture of the flux capacitor install?
Cheers
Justin
LMFAO! :yes: I'll pay that one.
Just unplug them and see if the miss is gone. This is called open loop.
Oh I already did this a few weeks ago and the miss was still there. :unsure:
Thanks guys!
What do you mean by brakes not as good as they should be?
As in making hissing (or bubbling) noise when it comes to complete stop as you'd felt on the pedal?
  • 3 weeks later...
Do the brakes get better with a few hard stops or do they fade? It is worth changing your brake fluid (any new fluid but something like Motul best). Otherwise a change of pads might be indicated. They could be track pads which don't pull up well when cold or they could be just rubbish pads (have a read of the brakes section for some suggestions) - I bought Pagid but they are quite expensive and there are other types that people like.
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
