R33 Gtr Missing At 3500rpm
Hi All,
I have a bit of an issue I can't put my finger on and I am hoping the SAU community can help.
I recently imported a 33 GTR and when I drive the car and keep it at a steady 3500 rpm there's a miss. Below and over 2500 rmp the car runs ok. Having said that the fuel consumption is very bad and there's plenty of back fire in normal driving.
I have done my home work and searched on this site and Google and the below have been helpful but not solved my issue.
What I have done:
  • Changed spark plugs to NGK BCPR7ES which I chose after reading a thread on SAU
  • Changed the fuel filter
  • Changed the CAS
  • Changed the pod filters to airbox
  • Changed AFM
  • Changed BOV's and checked piping was on tight
  • Changed the coil packs and sealed them with dielectric goo as the YouTube video suggested
The car sounds a little rough on idle but I am not sure if this is because the cam timing as the in was set to 0 and ex 2 degrees retarded. I noticed this when I did a full service on the car and I changed my timing belt. HKS cam gears came as a surprise. (the car was missing before the service)
The only thing I haven't changed is my injectors and fuel reg as one of the topics said that possibly could be the issue.
Before I start removing the fuel rail, injectors and reg is there anything else that could be causing this issue?
All your input will be greatly appreciated as I am stumped!
Thanking everyone in advanced.
Most likely a vacuum/boost leak.
Last time i had a miss it was the igniter module, in my case it was above 3500 but sounded like the wide spark gap or faulty coil pack issue.
In your case with backfire it sounds more like a Vacuum or boost leak, you need to check your hoses and pipes first.
Thanks guys!
I think you might be right about the vacuum leak as I believe the brakes are not as good as they should be. I have found a workshop that has a vac leak tester (think it's called a smoke test) and have a booking on Monday.
Having said that though I used carby cleaner and sprayed around hoses but I didn't notice anything.
Will keep you posted on the results/ solution.
Edited by manage13
Dead or failing o2 sensors do all those things...
Hi Trent,
Thanks for your response. Does the engine light come on when an 02 sensor fails? Currently I don't have the warning light. Also, if I plug a diagnostics tool will I be able to tell if the O2 sensor is failing?
Thanks.
.. r33 GTR missing at 3500rpm!
2 questions:
- Where did it go? I assume it came back/
- Do you have a picture of the flux capacitor install?
Cheers
Justin
  • Like 1
2 questions:
Cheers
Justin
LMFAO! :yes: I'll pay that one.
Just unplug them and see if the miss is gone. This is called open loop.
Oh I already did this a few weeks ago and the miss was still there. :unsure:
Thanks guys!
What do you mean by brakes not as good as they should be?
As in making hissing (or bubbling) noise when it comes to complete stop as you'd felt on the pedal?
  • 3 weeks later...
Do the brakes get better with a few hard stops or do they fade? It is worth changing your brake fluid (any new fluid but something like Motul best). Otherwise a change of pads might be indicated. They could be track pads which don't pull up well when cold or they could be just rubbish pads (have a read of the brakes section for some suggestions) - I bought Pagid but they are quite expensive and there are other types that people like.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
