Hi guys i have a gts4 with a full gtr gear box swap in it. The problem that im have is it isnt gripping in the front wheels like another box i had in there was graping (front wheels) prior to this one.
Is it possible that it needs to bleed up more. I bleed up until i saw no air, but this was from the back of the box and i know theres another spot by the motor on top the diff. Do you guys think this would cause a problem.?
Next is it possible to rebuild the transfer case as i dont mind doing it. Do you guys know of any threads here that has a step by step rebuild procedure just as a reference to follow.
Also whats the best place to find the replacement disks for the transfer case.
Thanks a million.
https://www.sau.com.au/forums/topic/458203-gtr-not-the-same-4-wheel-drive/
Do you have a gauge and is it showing torque being sent to the front etc?
If not, likely bleeding issue - seems the most common.
But yeah, if you haven't got the g sensors right (or even if they are not working) that can also cause it
Well all the electronics stayed the same all i did was change the gear box. Today i bleed both spots on the pump and the actuator on the rear of the transfer case. I have two different tires on the front. I ordered 4 of the same tires and will test it after they arrive. Last time i had all the same tires on the stock wheels and it seemed way more aggressive. I am noticing the gauge moving, its just not moving as much as last time. If the g sensor is disconnected wont the 4wd light come on. Thanks for the reminder. Ill check that cause i did have some of the wire disconnected to remove the torque split controller. Cant remember if it was plugged back up. I would figure the 4wd light would come on if that was disconnected???? The car i took the box out of only had 84k on the clock anf was always stock not even a boost controller in it.
Thanks for all the suggestion guys ill check that g sensor tomorrow first thing.
I can understand that. But i had the car set up the same way before the accident. Well just to add im using all the gts4 electronics. The only thing i can think of is i used the front suspension off the gtr because the gts4 wheel bearings were damaged. I would guess the front speed sensors are the same. As the drive shafts were.the same. Thats about the only electronics that was changed. I used the complete front suspension from the r32 gtr.
Did you check the wear on the attessa clutch plates before you installed the box?
:wacko::wacko:
No i just installed the box:wacko:
This why i was looking all over for a thread on the transfer case because i have 2 more and was wondering if i can stack another friction plate in there. I dont see it to hard to do.
I just cant find hard evidence of if its possible and what the results would be like.
Well yes, "sticking an extra friction plate in there" is essentially how you modify them for more front torque, just like tightening up the mechanical diffs.
I suspect there is a little more to it than just throwing an extra plate in as far as getting measuring and getting the right amount of forward drive without locking it up all the time, but if you understand how much extra you need then go for it!
If you look up the manual there is supposed to be a certain amount of clearance (for want of a better word) beyond the last plate. You measure this and shim the clutch pack to suit. A worn pack will have grater than acceptable clearance - the result is that the attessa system doesn't function properly because there is not enough force on the friction plates. The system displays the output on the dash - the output of the pump basically, not the torque output - it is too stupid to realise the clutch pack is worn. End result is the gauge wont help you diagnose a worn clutch pack, only a vernier will.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
