I’m in need of some advice regarding tires/wheels for dragracing, as dragracing Skylines isn’t that popular in the Netherlands I figured I’d post here in the hope you guys can help me out.
As of now the specs on my car are:
Stock spec 2 RB25det
Stock turbo
Tomei poncams
Boostcontroller set to @11 psi
3 inch frontpipe, decat, Apexi 3 inch catback
RSP/Bell’s stage 1 ECU
FMIC
HKS filter
We don’t have a dedicated dragstrip in the Netherlands, so most races are held on an airfield or on the straight of a circuit.
For the bigger events the “track” gets prepped but even then I seem to have problems running the times that I feel I should be able to run.
My best time for now is a 14.4@98 mph with a 60 ft of 2.3 which in my opinion is not up to the potential of the car.
I feel that I should be able to get some better times if I get my 60 ft times down but for that I would need to get some decent tires on the car, currently running my 18 inch wheels with 265/35’s
From reading a bit it seems that the MT ET streets are the way to go, I just don’t know which size to get.
I’ve been looking at the 255/60/15 and 255/50/16, the 16 inch being closer in overall size to what I’m currently running but which one would be better?
And would the stock R33 GTST wheel be adequate to run the 255/50/16 MT Streets?
https://www.sau.com.au/forums/topic/458205-advice-needed-on-drag-tires/
get some R32 GTR wheels if you can to fit 255's
Should be able to dip into the 13's with MT ET's. Though 98mph sounds like you're not getting value for money with your mods.
I did a similar time in my old R33 GTST with road tyres. dipped into 13.8 or 13.7 with MT ET's, with only boost, and exhaust.
Thanks for that, so 16's it is.
I'm not sure why my mph is so low, I did about 7 runs during the weekend and on 4 or 5 of them I ended up with a 14.7 @ exactly 157.21km/h each time which is about 98-99mph.
Like you say, I'm not getting value for money with my mods right now, compared to other Skylines I've driven it feels a bit tame.
I'm planning to do a boosleak check soon to start "troubleshooting"
Should I start stocking up on axles too when running the MT ET's :laugh:?
Thanks guys!
More power will be coming soon, saving up for a standalone,turbo, injectors and fuel pump right now.
Clutch is already changed for Nismo Super Coppermix kit
The ecu is a stock ecu with a flashed chip by RSP in the UK, nothing fancy but gets rid of the flat spot when turning up the boost.
As above... 98mph trap- your down on power or there is some funky gearing/ratio's going on. Plenty of people have run well into the 13's with stock turbo's.
For the kind of power your looking at, get a drag radial with a slightly lower rolling diameter than your 18's.
Diff, axles, half shafts and cv's are all fine.
J.
Thanks!
Good to hear that the drivetrain should be fine.
13’s was what I was expecting to run, so I was disappointed when I only managed to run mid to high 14’s all day.
The gearing is all standard as far as I know, the car was completely stock when it arrived from Japan.
On the ¼ mile I have to shift into 4th gear just before the finish.
I’ll be checking over the car the coming days to see if I can find out why it’s low on power.
Already ordered some new intercooler piping, as the current setup uses too much hose clamps and silicone joiners.
Also need to do a pressure test as I suspect that the bov is opening when on boost.
Hopefully it'll be fixed soon and run some good times with decent tires on it
Don't shit over the finish line, bounce the limiter if you have to for a fraction of a second. Just back off or shit after the finish line.
Stock BOV has a little hole in it that "leaks" to keep the transition between on an off boost smooth instead of hard on off.
Tyre's alone should see you do at least a 2.0 60ft and get you into the 13's.
Mate it seems you have bigger issues than what tyres to choose, your car is running similar times and MPH to what my non turbo 300ZX ran on $70 tyres. My bet is your CAS may not be set to 15* or something in your setup is restrictive as hell.
Thanks, I’ll add checking the timing to my list.
The current tires are worn out and need to be replaced, so might as well get some good tires on there right away.
Not sure where I should be looking for a restriciton though, exhaust is 3 inch all the way to the back except for the the turbo elbow which is stock.
Intercooler and piping is free off rags/newspaper or whatever could be stuffed in there.
Get the car to a good mechanical standard.
Replace the stock front pipe, dump pipe, down pipe.
Correctly install better intercooler pipe work... I'd bet you have multiple boost leaks.
Get it on a Dino.
J.
  • 10 months later...
Using this topic again.
I've now changed my intercooler, piping, checked the timing and managed to run a lower et of 14.2 @ 159 km/h while pedaling it in first.
Got the R32 GTR wheels and I am now looking to buy the MT's but it seems that the Mickey Thompson ET Street Radial Tire - 3793R is discontinued.
The replacement is the Mickey Thompson ET Street S/S - 3460, which is a steel belted tire, so it has a stiffer sidewall.
Are you guys still able to get the old model or are you running the new one and does anyone have any feedback on the new tire.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
