Please not CVT...please not CVT...please not CVT...
BMW announced the other day that it will no longer be building manuals. Auto's and their variants (DSG, CVT, etc) is our future.
:down:
I love the CVT in my Pulsar. I'd love a manual also, but I'm in traffic 99% of the time so I went CVT. It's good fun. I can play Mr Manual when I want a play or whack it into D when I don't.
Driving the Stag to work today solidified my decision to go the CVT.
  • Like 1
Yep, for a runaround/daily, CVT would be the go... if they're reliable (which they should be by now).
I've been giving my a hiding and 25,000ks in so far so good. I've already gone through a set of rubber.
It's the perfect gearbox for a daily. Super smooth and the manual mode allows it to act like a sequential box and have a bit of fun when I'm not stuck in traffic. It gets along quite well, too.
For a weekender/track car, no thanks, give me a Manuel. But lets face it, 99.999999999999999999999999999% of Altimas, Maximas, Pulsars, Jukes etc that Nissan ever sell, regardless of badge, will only every be daily drivers. Mine's a SSS and will never see track time.
Oh I'm not denying CVTs have their place, I just don't think they do the Nismo image any good. Other factory performance brands (e.g. Mugen) have lost their desirability by being watered down to little more than a trim level, I'd hate to see Nismo go that way too, it's already on shaky ground with the latest offerings.
IMO it should remain up there with the likes of AMG/Audi RS/BMW M, where the car remains a cut above the model on which it's based.
Correct me if i am wrong. The tweaked Nismo version wouldnt come with cvt because of the cvts limit with torque. As far as i am aware the cvt which holds record for highest torque output is the JR006E which was on the skyline v35 gt-8. I dont believe the brains at Nismo would even concider cvt. I do like the look of the car though. Maybe a 6 speed M/t would be the go.
  • Like 1
That makes sense.
I think you're giving NISMO a bit too much credit. They are in the business of selling cars, not appeasing the truebloods. If it comes to fruition and is sold in both CVT and manual, they'll sell 25 CVTs for every manual they sell. If it's manual only, the people who would have preferred a CVT will shop elsewhere. CVTs have their place in cars the people actually buy.
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
