Round 5 Saturday 15th August - Winton
acsplit
 Share
After a break in July the Motorsport Championship is back at Winton Motor Raceway (hopefully away from the wet weather).
- Current Championship results are here :http://sauvic.com.au/motorsport/2015_SAUClubChampionship.xlsx
- For anyone interested in attending their first track day here all you need to know : http://www.sau.com.au/forums/topic/453779-track-day-requirements/
This round we will be attending the day run by the Impreza WRX Club of Victoria who have kindly offered us affiliate club pricing for the round.
- This discount entry price of $190 is only valid until the 11th of August.
- Entries can be found here: http://www.wrx.com.au/event-1832172 Choose affiliate club entry
- Affiliate code : V4O34KL5 (make sure you put SAU VIC as your club and your valid member number)
You all have time to get your cars ready, if not come up and spectate as it is free.
Squires Loft Nunawading will be putting on lunch for all members not just ones competing on the day!
  • Like 1
I should be there at this stage as I've sorted out the gremlins with my car. Should the link to the championship spreadsheet be working as it doesn't work when I click on it?
What's the go with passengers at these events/trackdays? Not allowed?
Rarely... So much d**king around with extra insurance and forms and its generally only 1 x session near lunchtime...
You're always able to be a passenger in the drivers seat of your own car though.
I want to and will be at PI later this year if all goes to plan - was asking more if I could have a passenger as the girlfriend would love to accompany the drive.
Though it was cornerweighted with just the driver so I don't think it will be beneficial to my handling...still got a decent long wang time at deca so I'm eager to see what it can do around the corners at PI. I'm a better driver with sharp 2nd gear speeds; not sure how I'll go with the long sweepers.
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
