Location: VIC - Melbourne, Inner Northern Suburbs - LOCAL PICKUP ONLY
Price: $2500 ONO for Whole Car
Model: 1996 (Oct) R33 GTS-T Series 2
Colour: Silver
Engine: RB25DET - Completely Stock
Odometer: 105,000km
Mods: None
Rego: Valid till Oct 2015 - Declared repairable writeoff by Insurance. Not registered on WOVR due to car age >15 Years.
Let's get the nitty gritty out of the way:
Major Damage: Front Bumper Bar, Reo Bar, Radiator Support, Condenser and Fan, Radiator, Passenger door (small dent, scratches).
Mechanical: Needs new front shockers; Engine is in very good condition - has had welsh plugs replaced; Timing belt replaced at ~80,000km; New heavy duty clutch <1year old.
Electrical: Battery Flat, ABS light constantly on (may require new ABS unit), Driver side power mirror Y-axis control not working, Aircon vents click momentarily on cold start (possible stuck valve?), Radio Antenna stuck in lowered position (won't raise).
Minor Cosmetic Defects: See Pictures
For sale as Whole Car only (unfortunately do not have time or resources to part it out).
Refer to above descriptions for major details. Have owned car since it was imported from Japan in 2005 at 47,000km.
Serviced every 5,000km by performance mechanics, serviced with Motul oil.
Engine/Pulley's have no damage from accident (See detailed pics)
Boot is clean, have original spare wheel and tools.
Apart from issues described above, Chasis is straight and no other problems.
Car is stock - No mods to engine, exhaust etc...
PM for more info/contact details - can provide more pics if required.
Make me an offer!
post-140687-0-91364800-1436881994_thumb.jpgpost-140687-0-82001200-1436882045_thumb.jpgpost-140687-0-51836400-1436882093_thumb.jpgpost-140687-0-58095500-1436882149_thumb.jpgpost-140687-0-79582200-1436882203_thumb.jpgpost-140687-0-87767000-1436882250_thumb.jpgpost-140687-0-44446500-1436882299_thumb.jpgpost-140687-0-47483400-1436882345_thumb.jpgpost-140687-0-45382300-1436882382_thumb.jpgpost-140687-0-01964300-1436882624_thumb.jpgpost-140687-0-31357900-1436882667_thumb.jpgpost-140687-0-99197400-1436882713_thumb.jpgpost-140687-0-61671100-1436882761_thumb.jpgpost-140687-0-35761300-1436882812_thumb.jpgpost-140687-0-62885500-1436882859_thumb.jpgpost-140687-0-62398100-1436882898_thumb.jpgpost-140687-0-57563800-1436882941_thumb.jpgpost-140687-0-90165200-1436882989_thumb.jpgpost-140687-0-20496200-1436883035_thumb.jpgpost-140687-0-73388700-1436883122_thumb.jpgpost-140687-0-10497300-1436883170_thumb.jpgpost-140687-0-14853800-1436883220_thumb.jpgpost-140687-0-65830600-1436883260_thumb.jpgpost-140687-0-41217600-1436883314_thumb.jpgpost-140687-0-65494100-1436883419_thumb.jpgpost-140687-0-52021700-1436883478_thumb.jpgpost-140687-0-76111800-1436883528_thumb.jpgpost-140687-0-52422000-1436883590_thumb.jpgpost-140687-0-24279400-1436883685_thumb.jpgpost-140687-0-55705900-1436883732_thumb.jpgpost-140687-0-96358600-1436883781_thumb.jpgpost-140687-0-24184100-1436883833_thumb.jpg
Edited by R33Bit
  • 5 weeks later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
