Microtech MT-8 w/ Hand controller & RB20 Loom $500
Intercooler 600x300x76 w/ piping suit 180sx/s13 $100
New Nos Pod filter $5
Malpassi FPR $20
RB20DET engine suit rebuild $125
S15 New Front Rotors $100
V35 Front Bar $250
V35 Rear Bar $250
R34 standard filter box bottom half only $5
R34 GTT stockies $150
R34 Dash $50
R34 GTT Spoiler $80
R34 Coupe doors $50 each
R34 interior trim pieces $20 each
R34 Viscous Diff Centre $50
R34 Standard Gauges x2 $60
R34 Rear Hicas System x2 $40
CA18 Manifold $5
180sx Black tail lights $100
180sx headlights $30
180sx pig nose front bumper $150
180sx rear bumper $50
Ca/Sr non abs tailshaft $50
Ca18 a/c compressor $20
5 Bolt Dump pipe with front pipe $150
S14 Standard Fuel Pump/Assembly $5
RB20 Cross over pipe $20
GK Tech overflow bottle $20
R32 ECU $50
RB Gear Sticks with plates $20
Need space for more cars, Cheap prices for quick sales
Located: Tascott, Central Coast NSW 2250
Text or PM Anytime, 04049212eightseven
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
