Hey mate - There's quite a lot of rental places right on the ring that you can rent.
I personally used RSRNurburg. All the prices are pretty similar (expensive!) but.... I mean you're there, you pay the money, you do it, and have fun, and then you can say you did it.
Note: You don't need to rent the most amazing car to have fun there. I ended up doing it with the Clio RS with paddle shifters and had a blast.
Mind you, it was in the middle of winter and -2C, so in such sketchy conditions a Prius would have been a massive handful!
https://www.sau.com.au/forums/topic/458240-nurburgring/#findComment-7567991
Thanks for the hints n advice everyone. I was just thinking would it be ok if I rented a car from Munich airport, drive all the way up to the Nurburgring experiencing the autobhan at the same time. Use the same rental car to drive round the ring a few laps and head back to Munich or visit cologne. Your thoughts in this folks?
https://www.sau.com.au/forums/topic/458240-nurburgring/#findComment-7576024
Everyone visits colon in Germany
https://www.sau.com.au/forums/topic/458240-nurburgring/#findComment-7576057
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
