You got the car checked out, motor out, procured a new block and had it machined then engine back together in 2 days?
Sounds a bit suss if I'm honest.
It sounds very suss mate
But easily explained [emoji23] Hahahahaha
The work has been completed for a week or so I haven't had the time to post Up everything and I was interested to see if any other people have had similar issues.
  • 1 month later...
Just a quick update on the car
Polished the headlights finally made a massive difference to the front end of the car
b05bcd8f6efd1ca654fc2446c2134376.jpg9c828aea16e6e43bb063929dff86643a.jpg51a96b7434982f88ef7f3ee447eb0ddf.jpgec5825955c5d9f437c33f13b4a72e5fc.jpg16e0f0134db02d2acbb95d70b2f2b8eb.jpg
I have made a decision on what direction to take the car I have been all over the place trying to figure it.
I have entered an event for next year in WA called Racewars. It's a 1000m top speed event in Albany.
So this is it the vehicle left for Sydney on Monday when it returns it will be transformed into a monster I can't wait
#171daystillRW
  • Like 1
#171daystillRW
Who are you getting the work done by?
  • Like 1
I spent a bit of time checking out different workshops and the one that stood out to me Motorsport Mechanical
There cars are making good power and most importantly they are reliable
  • Like 1
  • 1 month later...
Well it's a while since I posted but the car arrived safely in Sydney and was driven straight to Motorsport Mechanical for its heart transplant and driveline upgrade
Mick sent me a couple the other day that made me very happy
  • Like 3
I have been waiting about a year and a half for a set of Works emotion D9r's to pop up for sale and finally it happened
The guy didn't have a clue what they were worth so I advised him that you could buy them brand new delivered to my door for about $1900
I offered $1500 cash and I would pick them up... he agreed and so the 6 hour round trip began to bunbury
Left a 7pm with an hours break I arrived home at 2am
It was worth the trip... they are brand new
2 hours ago, reaper said:
What size turbo is that? And did you go a 3.2 or what?
It's a Precision 76/75
I ended up going with a 2.8L stroker in an N1 block
Edited by frostyboy
My spelling is a joke
  • Like 2
  • 1 month later...
Well things have been moving forward at a good pace
The gearbox arrived with its new ppg gearset and dogsetit's been bolted up to a direct twin plate clutch kit
The full 4inch exhaust system is fitted and stops at the diff I will have my main man at The Exhaust center midvale fix that and make it more streetable with mufflers ect when it gets back
First startup went well with no issues
I have ordered the entire catalog off Haltech for my car it will be running flex system and a full Haltech iq3 street dash. This is a great option as it has indicators, high beam indicators and brake warning lights on them.
20161101_111038.thumb.jpeg.c7eca83f9cba120161101_111204.thumb.jpeg.3c90cdd7b0c26Resized_20161129_170843.thumb.jpeg.bdfc8Resized_20161129_172514.thumb.jpeg.04e05Resized_20161129_172527.thumb.jpeg.7fc1fResized_20161129_181007.thumb.jpeg.5747aResized_20161129_181023.thumb.jpeg.ad124Resized_20161206_170833.thumb.jpeg.2af0e need to add an extra 044
received_10210295838565778.thumb.jpeg.5areceived_10210295545558453.thumb.jpeg.0a
Make sure you head across the Motor Sports Mechanical and like there Facebook page to see live streams of the car
Motive DVD and Street FX will be doing a live stream on Facebook when the car is dynoed so keep an eye out
  • Like 4
  • 3 months later...
G'day fellas
It's been a while since I have updated everyone on the progress of the car
So just to go into more detail about the build I have listed everything I can remember from start to finish.
It's been a wild 6 months so let me try and remember what happened
The car arrived in Sydney and a base run was done on the Dyno the car made 520 horsepower at the rear wheels which was identical to what it ran over in the West besides from the cracked block the car was perfect maybe a bit rich on the tune
The boys at Motorsports Mechanical got started with pulling the old engine out of the car and having a look what they had to work with.
After the engine was out by sat down and had a conference call with Mick and we not it out a plan of attack for the build.
After much thought and deliberation we decided if we were going to go big. It was very important for me to retain the 2.6 litre configuration as I wanted to car to be able to read reliably so the decision was made to run the following combo
Motorsport mechanical 2.8 litre 1200 horsepower bottom end
All housed in a Nissan N1 Block
The cylinder head was a full CNC port job with oversized valves big cams double valve Springs and custom modified buckets so the vehicle could rev reliably
Our goal was at a minimum 1000 horsepower at all four wheels with a 10000 RPM limit
I wanted to retain the factory 6 throttle body setup and greddy plenum which looking at it now was probably something that I should have changed out for a hypertune manifold the car itself is at a level now that that would be causing a major restriction and stopping it from potentially making more power on less boost.
The fuel system had to be completely overhauled as my original goal with 600 horsepower the delivery would have never been enough the car now has 3x 044 pumps Walbro 460 pump in the tank twin Dash 8 supply lines with a dash 10 return Turbosmart 2000 horsepower fuel regulator keeps the pressures in check I run 6 Bosch 2000cc injectors through a larger diameter Billet fuel rail
The ignition system on the car is a work in progress unfortunately as with all big builds they have big costs and I ran out of money
The car was running Spitfires but we found it could not cope at these levels on boost and fuel delivery I now have on order a pro GTR Motorsport 2000 plus horsepower ignition coil setup 260 ignition issue
Turbo wise I've always been a fan of Precision turbos run precision 6466 on my F6 Typhoon which made 800 horsepower at the wheels Atlas and 24 pound I found it to be a very reliable turbo however a bit small for this combo
The car now runs a Precision 7675 turbo on a 6 boost manifold with a Turbosmart 60mm wastegate venting to atmosphere of course hahahahaha
The car runs a full 4 inch stainless steel exhaust system with a varex muffler at the rear which has a electronic control valve which opens and closes a flap to suppress exhaust noise this may need more work when it gets back to Perth as I have a feeling it's going to be way too loud and not practical for the street I will let Nick from the exhaust centre in Midvale check it out and he will hook me up with something more streetable
The car is running a quaife front diff and in 8 litre oversized sump and a nitto oil pump controls oil flow around the engine
As the car is going to be seeing 9000 + RPM we wanted to make sure the signal to the ECU was going to be faultless so we have now fitted by Ross trigger kit to the car
Mick is set up not catch can as well as or return mods and I will supply mods to the engine to help it live for the punishment I'm about to give it but this side of things is pretty hush hush Mick won't tell me alot
The car is now running a large radiator and thermo fan to help with cooling
Now the 5 speed factory gearbox was 100% not going to last so we purchased a PPG straight cut 1st to 5th dog gear set and added billet selector forks and a billet sandwich plate I have also added a lockout shifter which will stop the dreaded 2nd to 3rd miss shift which is very common when you're all geed up at the drag strip we are running a direct twin plate clutch which runs a 26 splined input shaft from PPG
Really I think the car needs a sequential at this level of power however my budget will not stretch hopefully down the track the car will get itself a ppg full sequential gearbox which from what I've heard are epic and the next best box to get for a new GTR
The car is had brand new brake booster brand new clutch slave and brake master cylinder fitted just to be sure that I'm not going to have any stupid failures
For a car at this level I needed to make sure I selected the right ECU the only real option besides from motec which once again was way out of my price range.
Haltech was the best choice for me great value endless capabilities and trick cool shit that I can't wait to set up I am running boost pressure coolant temp fuel pressure AFR intake temp sensors along with a Haltech flex sensor and digital street dash
First issue four-wheel drive wouldn't work the boys at Motorsports Mechanical started looking into this before dynoing the car it had always had an issue since I first built the car with Peter Grey and we never found time to get to the bottom of it Mick managed to bleed the full drive system replace a couple of users but the car still had a fault he ended up finding and ABS sensor which had rubbed on the chassis of the car causing it to go open circuit he replaced that and the four wheel drive light went out he cleared the codes put it on the Dyno but still had dramas with the four-wheel drive system not engaging after a stressful and frustrating phone call I convinced Mick to remove the console and inspect the g sensor after several tests we found a g sensor was not functioning correctly $100 later and a quick drive down the road we found a good second-hand G-sensor which hey fitted to the car problem solved
Second issue now running with all these fancy gadgets in the car led to another issue the car itself was struggling to keep good voltage to all the required sensors gauges etc at 9500 RPM the car was registering 11.5 volts at all three fuel pumps on the Dyno the car was not having enough voltage to run the full drive system so mid run the car would switch off the full drive system causing the car to go into rear wheel drive and smoke the tires on the Dyno
I ended up finding hey 150 amp alternator from America but after trial fit found it kept throwing belts and was Miss aligned if I had more time I would have made it work but unfortunately I didn't have time to mess with it so I purchased RH9 150 amp alternator bolt straight up good 10000 + RPM
Dyno time
The car when on the rollers and after doing all that bass fuel setups 98 Ron fuel the car went 650 horsepower at all four wheels
The fuel was and rained out of the car and E85 was added
After further runs on the car and fine tuning the car went 965 horsepower at all four wheels but unfortunately that's when we had a third issue
The car kept breaking down and it was agreed that the ignition system would not handle anymore power so we pull the car back to 900 horsepower until I have more funds to purchase some decent coil packs
PS these are now in order and hopefully we'll be fitted before I fly to Sydney on the 27th of this month hahaha these are now on order and hopefully we'll be fitted before i fly to sydney on the 27th of this month
Now the car is now running under its own steam I decided I would have it sent across to have a roll cage fitted
A few months ago I ran a group buy on roll Cage's from AGI I ended up purchasing 13 roll Cage's from them for guys in Perth saving them nearly 30% on the cost and freight of roll Cage's
The guys at AGI offered to fit my roll cage up and while we're there we did a quick video on the install of the cage 4 Motive DVD anyone who wants to watch it and how they are installed and how good the Cage's are I will add the link to the bottom of this thread
I have to say the Cage's epic and I'm very happy with the quality of install and from what I hear every person who purchased a cage through the group by extremely happy
The car itself has a long way to go until I am satisfied 100% what I want there is still a lot of work to be done but this will take time the car itself will run fast and and be an absolute ball tearer I can't wait to drive it next week
I probably missed a heap of stuff that has been done to the car but that's all I can think of for now
received_10154525394056715.thumb.jpeg.094eac30fdd1a8676e49cd00f7860b9e.jpegreceived_10154525393911715.thumb.jpeg.ce1227177086a52a2255bcddfbe4ea15.jpegreceived_10210978910444265.thumb.jpeg.6de85ca75abd324ed787c13809a81883.jpegreceived_10154382407486715.thumb.jpeg.cbe9cf5f2a70c4e16baa7f8b6bc0a828.jpegreceived_10154382407451715.thumb.jpeg.a52d9a35a34bf1ab7ed604a74d2b49e0.jpeg
  • Like 3
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
