trying to tidy up some wiring and unused components in my engine bay while its all apart.
got these 4 sensors going directly to the intake manifold on my r34 gtt.
can somebody please explain the function of each?
im assuming there is 1 for boost gauge, 1 for apexi pfc boost controller and 1 for ecu reference, what is the other one?
i am replacing the standard boost gauge so would like to remove the old sensor & plug.
also getting the apexi replaced with haltec platinum pro so will the haltec utilize the wiring ran for the pfc or can i remove/hide that?
The first one is the ECU's boost sensor, used for calling off the fun when the boost is too high.
The second one could be for just about anything, but not factory.
The third one is not a sensor, it appears to be a solenoid. It is probably the solenoid that regulates the application of vacuum to the charcoal canister.
The fourth one is like the second one - could be anything but wasn't put there by Mr Nissan.
The OEM dash MAP sensor is on the firewall near the brake booster.
the r34 uses map VE aswell for some calculations
It does, but the factory MAP sensor is plumbed in pre-TB (and hence pre-manifold). They seem to use some sort of pre-TB-MAP+TPS to calculate transient fuel requirements.
I moved my factory MAP sensor post-TB (now measuring manifold pressure) and the car totally died every time I changed the throttle position. After about 2 seconds it magically came back to normal. So I can say the stock ECU uses AFM for steady state airflow metering and pre-TB-MAP+TPS for transients.
Reason why I moved the MAP sensor was fitting an Adaptronic. Had to swap the stock ECU back in temporarily and it didn't like it! (Probably should have just unplugged the MAP sensor).
No idea why they fitted it pre-TB. You'd think post-TB would make more sense. Oh well.
The VE map is referenced off of things other than the boost sensor. The boost sensor is essentially just the fun police. It's never meant to see vacuum either (because of where it is) which is a good reason why poo poo happens when you move it behind the TB.
  • Like 1
Nothing to do with overboost I was nowhere near positive manifold pressure.
Has nothing to do with fun police or poo poo or any other vague suggestions like that. The sensor simply expects to see pre-TB MAP to do transient fuel estimates and the ECU doesn't cope when you show it a vacuum reading. Likewise if you just left it sensing atmospheric pressure it would still be a pile of shit on transient throttle as well (and leaving it atmospheric would defeat the fun police...)
The very same MAP sensor is now running my Adaptronic just dandy. Sensor doesn't care. Just the ECU is expecting pre-TB MAP.
  • Like 1
use the
correct its not the main load source only auxiliary.
Yes well that's the poo poo of which I spoke. Would have thought that was pretty obvious. Fun police not real vague either in a discussion that had already mentioned boost cuts.
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
