R33 GTR RB26 Built engine
Greddy forged Piston kit (Gudgeon pin/clips)
Standard balanced rods with Arp 2000 rod bolts
R33 GT-R crank - balanced, linished and crack tested
N1 oil pump
N1 water pump
Acl race series bearings (Big ends and Mains)
Block crack tested and painted
Blueprinted assembly
Metal triple layer headgasket
Tomei type A pon cams 260 x 9.15mm IN & EX
Hks adjustable cam gears
Gates racing timing belt kit (Belt pulley and tensioner)
Fully Reconditioned head - (new valve stem seals, valve guides and shims adjusted to suit camshaft profile)
All gaskets replaced with Nissan OEM
Comes as complete long motor with cold side intake - minus hot side (turbo side
NOTE: Engine accessories not included (Power steer pump/AC/Alternator) however matching timing cover is included. (no valley cover)
Engine was rebuilt by Advan performance in Sydney three years ago - has done 17,xxxKms since rebuild
Have thousands in receipts and also dyno papers i can provide for serious buyers.
Inspections more than welcome
Has been compression tested 150-153psi across the board
Comes with start up warranty
Reason for sale is vehicle was damaged by a rear end hit and written off. No damage to any running gear in accident.
Gold Coast
$6000 Please call or Text (Can freight Auswide through courier)
0414 596 256 - Johnny
Edited by slidinr32gtr
https://www.sau.com.au/forums/topic/458283-r33-gtr-rb26-built-engine-6000/
  • 1 month later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
