FD has better balance, infinitely better handling and stock for stock more reliable than shitty RB's
Finding an unmolested example of either is very difficult these days
FD's consistently hosed GTR's in the 12hr races in early 90's. That should give you a clue.
Rb over a rotor any day.
More grip
350kw on stock motor
Don't have to put 2 stroke in it to stop it burning oil
Better fuel consumption
350kw? are you high? more like 270 MAX. Struggle to hit that on a stock R.
I would argue that stock for stock GTR's are much more reliable TBH. Rotors are more touchy than a woman on her period.
Basically with a rotor be ready to rebuild it. They have massive overheating issues that you need to address properly. They have the smallest heat margin i have ever seen. It's something like 10 degrees is the difference between all is well and bang. They can be trouble when trying to push too much power out of them.
In saying that GTR's have issues as well. It all depends under what application you are driving. The oil control comes into play if you want to move them in any way.
So it depends. Do you want to spend thousands fixing cooling issues in the RX7 or thousands fixing oil issues in the GTR.
Both cars will require another $5000 around that ontop of what you spend to buy it at least to make them reliable. This is not taking into account performance upgrades at all, this is the money i would spend to make them daily reliable. Provided the engines are in good condition to start with.
Also FD's are f**king tiny. No space what so ever, many people i know struggle to even fit in them. Trying to get the interior to look nice with the required gauges you need is almost impossible.
FD's do handle really nicely in stock form. You could get one and not have to touch the suspension. GTR's are not tooooo bad. In stock form they will understeer, sway bars will counter this issue.
One of my very good friends has 2001 FD3s RS currently on the boat coming here. It's going straight to Ric Shaw to get intercooler, radiator, and gauges done. He isn't even confident to drive it back to canberra without the radiator and intercooler done. They are that bad.
TL;DR they are both money pits. Don't buy 1 unless you can afford 2.
Apart from that it will be personal opinion. What one do you prefer? Do you want the braap braap of a rotor or the howl of an RB?
just my 2c.
You talking rotors in general, or FD's in particular? When I had cooling issues, then fan-belt alignment issues I saw my 12A spike over 120 deg lots of times, and it spent a lot of time over 110 deg. Never went Bang, nor did it need a rebuild. Must admit it was getting a bit tired by the time I sold it - I'd spent 5 years rallying it, and god knows how long since it had a rebuild before I bought it (I'd sorted the cooling issues by then, and it ran a comfortable 90 deg no matter what I did to it)
Well maintained rotors are as reliable as anything else on the road. I'm hearing a lot more reliability issues from RB's than I do about injected rotors. Of course bolting a huge turbo and running 800HP out of a rotor is going to make it wear out faster.
Very true comment about personal preference. The RX7 was built from ground up as a sports car. The Skyline is a converted family car (although build quality is admittedly very good - no doubt about that). Different cars for different markets. Personally I'd go a stock FD over a stock GTR but I've always preferred nimble cars to brute strength. I think for dollars spent on mods, an FD would be faster and more reliable.
This
Just realised who OP is.
Nothing more than another theoretical discussion point, then.
Ask this same question at OzRotor and see what responses you get
Rotang FTW.
Just as long as you like noise and buying petrol and rebuilding motors.
Depends if you like Rb's or Rotors
Also depends what car you like the look of
I will own a RX3 Savana one day.
Been trying to convince my uncle to sell me his, Been sitting in the gararge for the last 15 years with a 20b or 26b from memory
they also lied about their engine capacity to win races.
they don't go that we'll for the 3.9l engine they are.
Personally, as a stock daily, you don't need to touch the oil system on a gtr.
short blasts are fine, and that's all you'd be doing on the road.
never had a problem with mine.
Not sure about the rx7 as I've never driven one, but would like to one day.
  • 10 months later...
