Hey guy's
My 33 is up the duff missing a little on idle and alot while driving on and off boost.
Quick idea of the build
Series 2 gtst
Rb25
Gtx3076
Haltech plug and play, wideband kit
740 side feed injectors
Exhaust, front mount
Everything to support 300kw
In the last few weeks its starting playing up, since chasing the miss ive done the following
Swapped cas
Swapped coolant temp sensor
Coilpacks swapped
Coil loom swapped
Injectors flowed and tested
Vacuum lines checked
02 sensor for wideband replaced
Compression test was ok
Two sets of plugged tried, gaps checked
Cleaned aac valve
The only thing that stood out, the fuel pump has a aftermarket relay that was melted but the fuse wasn't blown, the wiring is all good
Ive since replaced the relay setup, but no difference. Could my fuel pump be causing the problem?
So over it, please help!
Hey guy's,
Thanks for the responses.
Checked all cooler pipes cant find a leak, also replaced vac lines
Compression test was good. Approx 150 across all 6
I only have a short trip to work and I've noticed that once the cars warm the misfire goes away and it drives perfect again?
What controls the cold start, maybe its related
Thanks in advance
