Hello All,
Im looking for OEM part number for the Rb25det neo topfeed injector cushions!
Also has anyone ever had problems with a Freddy manifold leaking inbetween cylinder 2-3?? im pretty sure its just the cushions of a RB with sidefeed but just curious if its a problem..
https://www.sau.com.au/forums/topic/458322-rb25det-neo/
Well i diag it yesterday, For sure have leaking injector cushions/insultors were the injectors sit in the intake manifold (freddy) cant find any information on what size cushion i need for the stock topfeed injectors on the Neo engine.
https://www.sau.com.au/forums/topic/458322-rb25det-neo/#findComment-7570440
So i need some help getting a S1 Iacv wired up on the neo, through some research i found that the brown plug is what i need to wire in to have a decent idle after accel, right now im heel toeing to keep her alive. Anyone have an insight?
https://www.sau.com.au/forums/topic/458322-rb25det-neo/#findComment-7575368
  • 3 weeks later...
Well i got the fuel system installed an now have no start unless i use starting fluid, Fuel pump, CAS, injectors, an Fuel pressure are all correct. i have even checked voltage at the injector drivers, and coilpack drivers on the ecu.
https://www.sau.com.au/forums/topic/458322-rb25det-neo/#findComment-7587683
