INLET MANIFOLD TO SUIT R34 GT-t RB25 NEO
turbo side can suit earlier models.
Selling my turbo kit no longer needed as i'm going a different engine and this setup is not
suitable for what im chasing. only reason for removal is because my engine is now low on compression (was stock)
Only about 3000kms of work and has performed faultlessly. like new
Made 317rwkw at 20 psi on E85. only ran that on the dyno. street use was 17psi however turbo can run into the 25's
Parts include the following
Hypergear ATR43ss internal gate (500hp unit)
Earls turbo lines and fittings.
Stock exhaust manifold
tube and fin Intercooler 600x300x76 3inch inlet and outlets.
All clamps and silicon couplings
2 x 3 inch dump pipes. 1 with cat is stainless + high flow cat and other without a cat is iron.
PLAZMAMAN inlet manifold also includes their billet 80 mm throttle body.
catch can setup includes all fittings and hoses
Custom made aluminum intercooler pipes (TIG welded)
3 inch intake pipe
Brand NEW k&n pod filter
turbo beanie
Any questions don't hesitate to ask
still on car, only remove when i get a deposit
$2800
Thanks for looking
  • Like 2
https://www.sau.com.au/forums/topic/458328-turbo-kit-r34-neo/
  • 3 weeks later...
  • 1 month later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
