Hi guys,
Looking to buy 4 x 19 inch stockies from a v35 or v36 for my 35 sedan.
Rubber is currenty running low (bought the car with Nankangs, gross) and I figured 19s would be a nice upgrade from the standard 17s.
Have any of you done something similar?
I'm located in Sydney, Liverpool area; happy to cover shipping.
Cheers
https://www.sau.com.au/forums/topic/458329-wtb-oem-19-inch-wheels/
I have no idea where you drive, what the roads are like, or how long each day / week you spend in the car, but I have 19's on my FG (35 profile tyres) and the ride quality is pretty harsh. Every bump is amplified. If I was buying again I'd get 18's.
Seriously, the factory 19" rims on my V36 are just fine and comfy with 40 and 45 profile tyres.
That's a high profile for a 19in rim. I run 45 profile tyres on my 18s to get the right overall diameter. The 19s should have 35 profile tyres I believe. Unless you are running something like 205 tyres.
19s with 45 profile tyres should feel the same as 18s with 45 profile tyres anyway.
Edited by sonicii
Nope. Rears are 245-40 and fronts are 225-45 - as specified by Nissan for the V36 SP. Keep in mind though, maybe the V36 SP has the good fortune of being designed with such an outer circumference and the V35s need to be a smaller outer circumference by contrast. I don't know the specs for a V35 so I guess it would have to be a lower profile and would harshen up the ride a little.
  • Like 1
ah ok. the factory 18s on the V35 have 225/45 fronts and 245/45 rears. the stock 19s have 245/35.
The higher profile on the 19s on the V36 will make the ride about as smooth as the factory 18s on the V35.
245/40/19 is quite a big tyre. even the current commodore doesn't run a tyre that large.
  • 3 months later...
Just thought I'd chime in and give major credit to AsM for being a pleasure to do business with. If he ever has anything else to sell you, what you see is what you'll definitely get without any mucking around. I'm still not sure about the rims being black - very good paintjob though! Even if I do repaint them to OEM spec, it's still going to work out cheaper than buying a new set from the dealership!
Many thanks AsM.
  • Like 1
Bugger. The only vibration I get is when I apply the brakes at high speeds. Then again, I do drive like an arsehole. :P
You'd want to be careful though because those vibrations carry through to other hardware in the chain that will prematurely wear or fail as a result. It's not just about what's happening at your steering wheel.
Edited by The Max
Hello! I am Actually selling my 19" Stockies. They have some rash and are plasti dipped black but I started peeling them off to sell them, then quit cuz I couldnt be bothered to peel them Lol.
They have achilles tyres wrapped all around with over 70% tread I'd say. 1300 ONO for all plus shipping if anyones interested.
Many thanks AsM.
Thank you for the kind words Tony but credit goes to you as well for being a hassle free buyer :)
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
