Hi guys,
Looking to buy 4 x 19 inch stockies from a v35 or v36 for my 35 sedan.
Rubber is currenty running low (bought the car with Nankangs, gross) and I figured 19s would be a nice upgrade from the standard 17s.
Have any of you done something similar?
I'm located in Sydney, Liverpool area; happy to cover shipping.
Cheers
https://www.sau.com.au/forums/topic/458329-wtb-oem-19-inch-wheels/
I have no idea where you drive, what the roads are like, or how long each day / week you spend in the car, but I have 19's on my FG (35 profile tyres) and the ride quality is pretty harsh. Every bump is amplified. If I was buying again I'd get 18's.
Seriously, the factory 19" rims on my V36 are just fine and comfy with 40 and 45 profile tyres.
That's a high profile for a 19in rim. I run 45 profile tyres on my 18s to get the right overall diameter. The 19s should have 35 profile tyres I believe. Unless you are running something like 205 tyres.
19s with 45 profile tyres should feel the same as 18s with 45 profile tyres anyway.
Edited by sonicii
Nope. Rears are 245-40 and fronts are 225-45 - as specified by Nissan for the V36 SP. Keep in mind though, maybe the V36 SP has the good fortune of being designed with such an outer circumference and the V35s need to be a smaller outer circumference by contrast. I don't know the specs for a V35 so I guess it would have to be a lower profile and would harshen up the ride a little.
  • Like 1
ah ok. the factory 18s on the V35 have 225/45 fronts and 245/45 rears. the stock 19s have 245/35.
The higher profile on the 19s on the V36 will make the ride about as smooth as the factory 18s on the V35.
245/40/19 is quite a big tyre. even the current commodore doesn't run a tyre that large.
  • 3 months later...
Just thought I'd chime in and give major credit to AsM for being a pleasure to do business with. If he ever has anything else to sell you, what you see is what you'll definitely get without any mucking around. I'm still not sure about the rims being black - very good paintjob though! Even if I do repaint them to OEM spec, it's still going to work out cheaper than buying a new set from the dealership!
Many thanks AsM.
  • Like 1
Bugger. The only vibration I get is when I apply the brakes at high speeds. Then again, I do drive like an arsehole. :P
You'd want to be careful though because those vibrations carry through to other hardware in the chain that will prematurely wear or fail as a result. It's not just about what's happening at your steering wheel.
Edited by The Max
Hello! I am Actually selling my 19" Stockies. They have some rash and are plasti dipped black but I started peeling them off to sell them, then quit cuz I couldnt be bothered to peel them Lol.
They have achilles tyres wrapped all around with over 70% tread I'd say. 1300 ONO for all plus shipping if anyones interested.
Many thanks AsM.
Thank you for the kind words Tony but credit goes to you as well for being a hassle free buyer :)
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
