Hi All,
R34 GTR V Spec for sale
Colour: Bayside Blue
KM: 58,600
Rego Ends: 21.07.2016
Year Model: 1999
MODS:
Nismo Fuel Pump
Nismo Replica Side Skirts
Nismo Replica Rear Pods
Nismo Twin PLate Clutch
Nismo N1 Turbos
NISMO S-Tune Suspension
Apexi front pipe
Adjustable Cam Gears
Splitfire Coil Packs
Apexi Power FC
KOYO Radiator
Gram Lights 57s Pro Titanium 10.5 x 19 +22
All above parts were done by the previous owner except the KOYO radiator, NISMO S-tune suspension and the Gram lights.
Spare Parts:
Tein Super Street Coilovers (Used in box)
HKS AFM Adapter (Brand new in box)
KTS Cool Power Suction Kit (Brand new in box)
Power FC D Jetro with boost solenoid (Brand new in box)
Issues:
- Rear diffuser has been bent up by previous owner, this has been straightened up and can be seen on a hoist only.
- 2cm crack on front bar near right hand side wheel well (See picture).
- Reverse gear is hard to slot in, my mechanic believes the clutch/ flywheel is warped (clutch possibly not installed correctly by previous owner), issue should disappear when new clutch/ flywheel goes in. At this point I have to put the stick into 5th, 6th, 5th, 6th and then it will slot into reverse. Every other gear slots in with no issues or crunches.
Due to the above issues I am pricing the car cheap at $45,000 FIRM. Spare parts can be added if the buyer wants, I will adjust the price accordingly.
I also have the de registration certificate from JAP ODO Check.
Contact me on 0402 292 385, SMS is preferred as I cannot pick up my phone during work hours.
Cheers,
Will
Edited by Hargow
https://www.sau.com.au/forums/topic/458336-fs-r34-gtr-v-spec/
I haven't really asked, but I guess it depends on what clutch you going with.
I was planning to tune the car first and use up the current clutch, then put in a twin plate NISMO Copper Mix to handle the 300kwatw I was after.
Roughly $1800 for the Nismo Copper Mix twin plate clutch
Delivery is $141.09 from RHD Japan
http://www.rhdjapan.com/nismo-super-coppermix-twin-plate-clutch-bnr34.html
Labour $550 - $600
But you don't have to go down that path, you can always choose a different clutch.
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
