Hi Guys,
I have Power FC
Tomei Cams
-5 Turbs
700-800cc Cant remember
Fuel pump
spitfire coils
Straight cut PAR Latest revision - Issues seem to have been ironed out
18Psi 340awkw
3inch Exhaust
Cat converter upgraded
Some other things also , just in a rush---
My aim is e _ flex
Can you please list all the parts I need? fopr this, it will be my final build, I want everything immaculate - Also ant the block Strengthened , I was thinking getting an N1 and strengthening this as a base, I will also be getting the Spoon RB29 Kit to match with it, I want to keep the -5s As I think this and the rb29 will be a great mix.
If someone with GREAT knowledge list the parts I need so I can start doing my own research and comparing.
https://www.sau.com.au/forums/topic/458339-help-needed-parts-list-wanted/
Everything you need has been posted on here many times.
Injectors are too small
So is exhaust
You'll need a different ECU to run the flex fuel gear
What clutch have you got? You MAY need to upgrade that if you're really turning the wick up.
Oil pump
Water pump
Gasket kit
Head service at the minimum
Head studs
Main studs
What will you be doing with the sump?
And don't forget a real front diff!!!
