I'm hoping to get some suggestions on fixing a fault with my R34 turbo factory boost gauge in the dash cluster.
It works intermittently, I see no pattern, it doesn't start working while driving if it didn't at start up, it either comes on and works or doesn't and may come on after a drive, after car is restarted.
Any advice appreciated.
https://www.sau.com.au/forums/topic/458341-r34-oe-boost-gauge-fault/
Common problem. Open up the sensor, it's located near the shock tower, and redo the 3 solder points.
Someone wrote up a guide on how it's done before, pretty informative, I followed it to fix mine last weekend.
While you're at it check the line as well, 90% chance it's probably split
