Just clearing out my garage after moving as I have too much stuff - especially wheels.
4x Works 17x8 +35 rims (unsure of model name) - $500ono
2x brand new 235/45R17 tyres (I think Hiflys)
2x aged/used 245/45R17 Dunlop semi slicks
*****I purchased these as a used set of rims for skids/drifting and are not in perfect condition but hold air perfectly and balanced up fine when the tyres were fitted
2x Rota P45R2 18x9.5 +20 (matte black) - $650ono
2x near new 235/40R18 Maxxis tyres
*****I purchased these brand new and have babied them, only been driven on the street for around 10,000kms
2x Rota DPT 18x9.5 +22 (matte black) - $550ono
*****Purchased these used and they have a few small marks from various track days but balance up perfectly as well
2x Rota DPT 18x9.5 +22 (rattle can blue) - $150
2x near bald 235/40R18 tyres
*****Purchased used with the above pair however have copped much abuse from drift days and are both buckled. One rim has had a crack repaired. Both hold air fine but are definitely not suitable for on the road
Will take $1100 for the 4x good Rota's or $1200 for all 6.
All wheels located in Bathurst NSW, willing to post at buyers expense or alternatively meet as far as Lithgow or Sydney/Canberra at a convenient time.
https://www.sau.com.au/forums/topic/458359-garage-cleanout-wheels/
Price drop on wheels - does not include deilvery
2x Rota P45R2 18x9.5 +20 (matte black) - $600
2x Rota DPT 18x9.5 +22 (matte black) - $500
2x Rota DPT 18x9.5 +22 (rattle can blue) - $100
All 6 wheels/tyres for $1050
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
