Clearing out my garage after moving and seeing how much stuff I have.
Stock R34 GTT radiator - $100
**Only replaced due to upgrading to a Fenix 52mm, no leaks
Stock R34 GTT Thermostat - $15
**Only replaced due to upgrading to a Nismo item
Stock R34 GTT rear camber arms (pair) - $50
Stock R34 GTT rear traction arms (pair) - $40
Stock R34 GTT front upper control arms (pair) - $80
Stock R34 GTT front swaybar - $50
Stock R34 GTT rear swaybar - $50
**Only replaced due to upgrade for adjustable parts
Stock R34 GTT front brake rotors (pair) - $50
DBA4000 T3 series slotted front rotors (pair) - $200
Stock R34 GTT front calipers (pair) w/ Intima SR pads- $300
Intima SR rear R34 GTT brake pads - $20
HEL R34 GTT front braided brake lines - $60
**Only replaced due to upgrade, heaps of pad left on the front and rears
Ferodo GP2 rear R34 GTT pads (brand new) - $20
**To confirm fitment - Part No. DB1144GP. I was given these when I purchased the car but never used them
Unknown brand front Evo 5-9 Brembo pads - $20
**Replaced after fitting up the Brembos to my car, reasonable amount of pad left
Stock R34 GTT center gauge cluster - $100
**Removed for fitment of Defi gauges
Stock R34 GTT transmission mount - $100
**Only removed due to being replaced with Nismo item
Stock S15 rear camber arms (pair) - $50
**Removed from my old S15 and replaced with adjustables
S15 rear parcel shelf speaker grills - $10
BMC pod filer - $10
**Could use a clean and also has a screw hole in the end from a bracket, was given to me when purchasing another filter setup
If you want a better picture of any of the items, or of any of the items not pictured, let me know, I've been meaning to post this for a couple of weeks and have just been lazy with taking photos so just wanted to get something up. Will happily get pics if anyone is interested though.
All parts are located in Bathurst NSW, willing to post at buyers expense or alternatively meet as far as Lithgow (for multiple items) or Sydney/Canberra at a convenient time as I travel these ways often.
Intima rear pads sold pending payment
Front swaybar sold pending dropping off/payment
Has also been a couple of people interested in the DBA rotors but nothing set in stone yet
Pictures of front calipers as requested. They are a bit dirty but paint appears to be good, and as you can see the Intima Pads have heaps left on them.
HEL braided lines sold seperately or can bundle for the right price.
  • Like 1
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
