Ok hi guys, so I've been reading stuff from SAU for years but just made the account and first post here :) I've got an r33 gtst s2 with the following:
Front mount
T3/t04e turbo
Sard fuel reg
Walbro 255lph fuel pump
Bosch 740/760 injectors (couldn't remember if it's 740 or 760 off the top of my head)
Spitfire coil packs
Coil over suspension
Heavy duty organic clutch
Wide band
Haltech platinum ecu
Full 3 inch exhaust
Greedy profec b boost controller ( set to 14 and 17 psi for 230/255rwkw )
Just had a major service and compression test done and all cylinders are at 150-170 psi.
Pretty sure that's the lot, maybe a few other things but that gives u guys a good idea of what I'm working with. Now I'd like to see 300rwkw but before that I want to swap my intake mani for an oem one that doesn't run across the top of the motor as I'm sick of removing piping for basic stuff like changing plugs etc so was just curious if I'll need a retune straight away? And if a few people could suggest ways of moving forward to a reliable 300rwkw I'd appreciate it :)
Mark.
Most certainly a retune, you're altering the air supply which means altering the fuel.
However you would benefit FAR more from spending the money on a decent turbo on than changing inlet manifold. You'd live with an extra 10mins to do plugs if you could pick up both power and response every time you drive it.
You've spent decent money on things like a Haltech ETU, Wideband yet you've got a turbo from the 1970s on there, does the setup zero justice IMO.
And realistically based on your power vs boost figures, at a very broad guess, the turbo would seem to be running out of puff anyway meaning 300rwkw is going to be almost an impossible stretch. It *might* be doable with E85 but not if you're outta turbo flow, which seems to be the case.
Well my problem now is funds, it wasn't so when I did most of these mods and for the life of me can't get a consistent answer for what a good turbo replacement ? Obviously I'd love to be running a garret gtx3582r but it's a bit pricey :/ nismoid could u list me some different options of what u would replace it with? Based on price/performance etc?
A turbo is the MOST important part, bar none. Cheap out there, the rest of the set up will never be as good as someone with a better turbo for the power/area etc.
If you've read the forums as much as you have said, you'd know the GT3076 in a .82 rear would be the most popular pick for 300rwkw.
Read the dyno thread, pages of GT3076 results to look at.
Or consider something more on a budget from Hypergear. Again, they have a long detailed thread, you've just gotta decide for yourself.
I get that the gt3076 with the .82 rear housing is the most common but if I don't mention any bias opinions of turbos I might have someone like yourself looking at my setup might tell me a better option, thanks
If you leave the valley cover off you can change plugs without removing the crossover pipe. it's a bit more fiddly and you need a wobbly socket (uni joint) but it can be done.
actually on my R33 I sliced the rear part off so the valley cover was completely flat (rather than bending down at the back of the motor). then you can get it in and out without touching the crossover pipe as well.
but really it should only take a couple of minutes to pull the crossover pipe. front facing plenums have issues with uneven flow distribution - unless you buy an expensive one that has been flowbenched and proves even air distribution to each cylinder. that's a lot of money to spend to avoid a small inconvenience, but each to their own.
See that's the first I've heard of uneven flow distribution with the oem manifolds so maybe I haven't done as much research as I should've, thanks for that kinks and it's not so much that it's an effort or time consuming to take off cross over pipe it's just that its a pain in the ass doing it everytime and it looks so much cleaner having the forward facing plenum
And nismoid I was previously looking at an ATR43SS1PU hyper gear turbo with .86mm rear housing with the rb25 Bolton assembly. as much as I want a certain power figure I want it to be achieved without too much lag so do u think I'd be happy with that turbo?
And anyone else who wants to throw their 2 cents by all means please do
My 2c? First I have to ask what it is exactly that you mean by "oem plenum"? Do you realise that OEM means Original Equipment Manufacturer? It doesn't mean "aftermarket", or "forward facing" or whatever else it seems you think it means.
The extra bonus 1c is about it being a pain in the arse to do it every time. Wow. That's like, I dunno. A couple of times a year. I would go crazy under those circumstances.
The extra extra bonus 0.2c is to point out that appearances under the bonnet are clearly more important than functionality and you should remember that and stick to it at all costs. Don't let anyone tell you different.
  • Like 1
No....a forward facing plenum is an an intake manifold with the throttle body "facing forward" in visual terms, and in regards to the oem I was under the impression that Nissan had made some of these intake manifolds with the "ffp" or "forward facing plenum" design because so many people didn't like the look of and functionality of having the crossover pipe from the standard manifold...appreciate the comment though..
id advise looking through peoples build threads and the turbo and power thread http://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page-1you'll soon see what's reliable and what turbo makes what power with other modifications. May seem like a bit of work, but that's half the fun and it will broaden your ideas and open new possibilities.
Changing plugs isn't that much of an inconvenience with the standard plenum and J pipe. Should only take a few minutes, like 5-10 tops.
FFP do look nice if they are rippled like standard, i have never used one or seen a back to back test vs standard so i can't comment on their 'power'.
Take a good look at the engine bay and you'll soon realise that the wiring loom, vac hoses, and power steering reservoir etc are the things that 'clutter' the engine bay. Personally, i'd start with a wire tuck and moving reservoirs if you're into cleaning it up a bit. It will be cheaper and keep you 'tinkering' for longer. Ever seen a 25 wire tucked and cleaned? looks a shitload better than a cluttered bay with a ftp.
The OEM plenum is, as has been pointed out, the one that came with the car. No Nissan didn't make a FFP for you . The one on the GTR is a whole other ball game with the individual throttle bodies. Your best bet is to contact Hypergear, tell him what you want and buy what he suggests. Better still have a read through the Hypergear thread first. And when you have saved the money for the turbo save up enough money for a first class tune or else all your other money is wasted.
Takes me about 10 minutes tops to do a plug change on my RB25. I have standard side facing plenum. I don't run a valley cover.
Your setup should get you what you want with a new turbo. Either a Garrett 3076 if you got the cash or I believe a Hypergear ATR43SS2 will get you there for a hefty dollar saving.
If you want spend 1k on a mod that will make you go backwards in performance go for it lol all youll gain is a nice engine bay photo and save 2min on undoing couple of hose clamps on the cross over once a year when u do plugs and at the same time youll make the oil filter harder to get to which is the more common change unless your running a relo filter.
  • Like 1
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
